Possible Duplicate:
How do I install BCM4312 wireless drivers?
Below are the results for sudo lshw -c network command. I believe "UNCLAIMED" refers to missing drivers.
*-network UNCLAIMED
       description: Network controller
       product: BCM4311 802.11b/g WLAN
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:0c:00.0
       version: 01
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:f1ffc000-f1ffffff
  *-network
       description: Ethernet interface
       product: NetXtreme BCM5755M Gigabit Ethernet PCI Express
       physical id: 0
       bus info: pci@0000:09:00.0
       logical name: eth0
       version: 02
       serial: 00:1c:23:2f:06:45
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.116 firmware=5755m-v3.29 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:45 memory:f1ef0000-f1efffff
baskint
  • 101
The STA driver in 11.04 doesn't work due to a kernel issue. You will have to install the B43xx firmware. Just install firmware-b43-installer from the software center or synaptic.
You can also do it from the command line.
sudo apt-get install firmware-b43-installer
Jeff Rash
  • 131
