I am having some trouble in starting more then one process in a single terminal window..
like as i have started wvdial by
sudo wvdial
it shows all initiating process details but wont give back
pankaj@N5010:~$
until i press ctrl+c to terminate which causes terminate wvdial..
what i want is to start both wvdial and nautilus in same terminal window.Is it possible??
Sukupa91
  • 3,067
Yes you can. Just append the ampersand character (&) at the end of the command. This will allow the program to run as a background job in the shell. Like this:
sudo wvdial &
nautilus
It's worth nothing that you will still see terminal output from the task while it's running in the background.
Yong Jie Wong
  • 571
Append the first command with an ampersand & which makes the command run in the background. man bash says:
If a command is terminated by the control operator &, the shell executes the command in the background in a subshell. The shell does not wait for the command to finish, and the return status is 0.
K7AAY
  • 17,705
