Problem:
I'm trying to install OpenCV (video analytics) and am following the Ubuntu OpenCV installation documentation.
The provided script has a line which executed for some time, taking away more packages than I expected (such as ubuntu-studio video):
sudo apt-get -qq remove ffmpeg x264 libx264-dev
When the script gets to the line below, it bombs:
sudo apt-get -qq install libopencv-dev build-essential checkinstall cmake pkg-config yasm libtiff4-dev libjpeg-dev libjasper-dev libavcodec-dev libavformat-dev libswscale-dev libdc1394-22-dev libxine-dev libgstreamer0.10-dev libgstreamer-plugins-base0.10-dev libv4l-dev python-dev python-numpy libtbb-dev libqt4-dev libgtk2.0-dev libfaac-dev libmp3lame-dev libopencore-amrnb-dev libopencore-amrwb-dev libtheora-dev libvorbis-dev libxvidcore-dev x264 v4l-utils ffmpeg
The error message is:
Attempted Solutions:
I first ran Update-Manager, ran sudo apt-get update, rebooted, tried to run the above script line manually, and still no change.
Thereafter followed the answers given at:
I ran sudo apt-get install -f and nothing seemed to change. It did mention that some packages were no longer needed and could be removed by apt-get autoremove, so I ran that. It removed a number of packages, so I reran the install command above. Still same problem of held broken packages.
I then ran sudo apt-get -u dist-upgrade, part of the resulting response was:
The following packages have been kept back: gstreamer0.10-ffmpeg
I'm not sure what that means. I do know that it shows up in my Update-Manager and cannot be checked.
I then ran
sudo dpkg --configure -a
and then reran
sudo apt-get -f install
and the package was still not upgraded, though there was this very interesting comment;
gstreamer0.10-ffmpeg : Depends: libavcodec53 (< 5:0) but it is not going to be installed or
libavcodec-extra-53 (< 5:0) but 5:0.7.2-1ubuntu1+codecs1~oneiric2 is to be installed
Then I ran
It showed I had one held package, so I ran
sudo apt-get -o Debug::pkgProblemResolver=yes dist-upgrade
It also exited without upgrading the package, so I ran
sudo apt-get remove --dry-run gstreamer0.10-ffmpeg:i386
And it gave me:
*The following packages will be REMOVED:
arista gstreamer0.10-ffmpeg
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
Remv arista [0.9.7-3ubuntu1]
Remv gstreamer0.10-ffmpeg [0.10.12-1ubuntu1]*
But when I reran
It showed the package was still there.
*The following packages have been kept back:
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.*
Thereafter, went into Synaptic PM and completely removed gstreamer0.10-ffmpeg.
Reran
And was told
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
However, when I ran the original apt-get command to install opencv (first code at the top of this question), it still gave me the same broken package errors.
So I tried:
$ cat /etc/apt/sources.list
deb cdrom:[Ubuntu-Studio 11.10 Oneiric Ocelot - Release i386 (20111011.1)]/ oneiric main multiverse restricted universe
See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
newer versions of the distribution.
deb http://us.archive.ubuntu.com/ubuntu/ precise main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ precise main restricted
Major bug fix updates produced after the final release of the
distribution.
deb http://us.archive.ubuntu.com/ubuntu/ precise-updates main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ precise-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb http://us.archive.ubuntu.com/ubuntu/ precise universe
deb-src http://us.archive.ubuntu.com/ubuntu/ precise universe
deb http://us.archive.ubuntu.com/ubuntu/ precise-updates universe
deb-src http://us.archive.ubuntu.com/ubuntu/ precise-updates universe
team, and may not be under a free license. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb http://us.archive.ubuntu.com/ubuntu/ precise multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ precise multiverse
deb http://us.archive.ubuntu.com/ubuntu/ precise-updates multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ precise-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb http://security.ubuntu.com/ubuntu precise-security main restricted
deb-src http://security.ubuntu.com/ubuntu precise-security main restricted
deb http://security.ubuntu.com/ubuntu precise-security universe
deb-src http://security.ubuntu.com/ubuntu precise-security universe
deb http://security.ubuntu.com/ubuntu precise-security multiverse
deb-src http://security.ubuntu.com/ubuntu precise-security multiverse
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu precise partner
deb-src http://archive.canonical.com/ubuntu oneiric partner
Uncomment the following two lines to add software from Ubuntu's
'extras' repository.
This software is not part of Ubuntu but is offered by third-party
developers who want to ship their latest software.
deb http://extras.ubuntu.com/ubuntu oneiric main
deb-src http://extras.ubuntu.com/ubuntu oneiric main
deb http://download.opensuse.org/repositories/home:/popinet/xUbuntu_11.04 ./ # disabled on upgrade to precise
Thereafter, I ran:
$ sudo apt-get check
Reading package lists... Done
Building dependency tree
However, no resolution of the problem yet, as I still get the same broken package message when I attempt to run the install of OpenCV with this command:
I then ran:
$ sudo apt-get autoclean
Del linux-generic 3.2.0.55.65 [1,714 B]
Del linux-libc-dev 3.2.0-54.82 [858 kB]
Del initramfs-tools-bin 0.99ubuntu13.2 [9,758 B]
Del firefox-globalmenu 24.0+build1-0ubuntu0.12.04.1 [8,958 B]
Del apport 2.0.1-0ubuntu17.5 [147 kB]
Del firefox-locale-en 24.0+build1-0ubuntu0.12.04.1 [578 kB]
Del thunderbird-locale-en-gb 1:24.0+build1-0ubuntu0.12.04.1 [14.0 kB]
Del linux-libc-dev 3.2.0-55.85 [860 kB]
Del thunderbird-globalmenu 1:24.0+build1-0ubuntu0.12.04.1 [8,782 B]
Del apport-gtk 2.0.1-0ubuntu17.5 [9,200 B]
Del thunderbird 1:24.0+build1-0ubuntu0.12.04.1 [29.3 MB]
Del firefox 24.0+build1-0ubuntu0.12.04.1 [28.1 MB]
Del thunderbird-locale-en-us 1:24.0+build1-0ubuntu0.12.04.1 [14.0 kB]
Del linux-image-generic 3.2.0.54.64 [2,262 B]
Del linux-headers-generic 3.2.0.55.65 [2,244 B]
Del linux-image-generic 3.2.0.55.65 [2,260 B]
Del python-apport 2.0.1-0ubuntu17.5 [81.1 kB]
Del initramfs-tools 0.99ubuntu13.2 [49.2 kB]
Del linux-headers-generic 3.2.0.54.64 [2,258 B]
Del linux-headers-lowlatency-pae 3.2.0.55.44 [2,256 B]
Del linux-headers-lowlatency-pae 3.2.0.54.43 [2,250 B]
Del thunderbird-locale-en 1:24.0+build1-0ubuntu0.12.04.1 [342 kB]
Del python-problem-report 2.0.1-0ubuntu17.5 [9,466 B]
Del procps 1:3.2.8-11ubuntu6.2 [225 kB]
Del linux-generic 3.2.0.54.64 [1,722 B]
But when I run the OpenCV install command, I still get:
So then I started almost completely over again, this time adding back in repositories that the upgrade to Precise had disabled.
Then I reran the following commands:
$ sudo apt-get clean
$ sudo apt-get -f install
The following package was automatically installed and is no longer required:
python-gudev
Use 'apt-get autoremove' to remove them.
$ sudo apt-get autoremove
python-gudev
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 106 kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 614874 files and directories currently installed.)
Removing python-gudev ...
Processing triggers for python-support ...
$ sudo dpkg --configure -a
$ sudo apt-get -u dist-upgrade
Calculating upgrade... Done
$ cat /etc/apt/sources.list.d/*
THIS FILE IS AUTOMATICALLY CONFIGURED
You may comment out this entry, but any other modifications may be lost.
deb http://dl.google.com/linux/earth/deb/ stable main
deb http://ppa.launchpad.net/kxstudio-team/ppa/ubuntu precise main # disabled on upgrade to precise
deb-src http://ppa.launchpad.net/kxstudio-team/ppa/ubuntu precise main # disabled on upgrade to precise
deb http://ppa.launchpad.net/kxstudio-team/ppa/ubuntu oneiric main
deb-src http://ppa.launchpad.net/kxstudio-team/ppa/ubuntu oneiric main
Please report any bug on https://bugs.launchpad.net/medibuntu/
deb http://packages.medibuntu.org/ precise free non-free #Medibuntu - Ubuntu 11.10 "oneiric ocelot" disabled on upgrade to precise
deb-src http://packages.medibuntu.org/ oneiric free non-free #Medibuntu (source) - Ubuntu 11.10 "oneiric ocelot"
deb http://packages.medibuntu.org/ oneiric free non-free #Medibuntu - Ubuntu 11.10 "oneiric ocelot"
#deb-src http://packages.medibuntu.org/ oneiric free non-free #Medibuntu (source) - Ubuntu 11.10 "oneiric ocelot"
deb http://www.openfoam.org/download/ubuntu precise main # disabled on upgrade to precise
deb http://www.openfoam.org/download/ubuntu oneiric main
deb http://ppa.launchpad.net/webupd8team/java/ubuntu precise main
deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu precise main
Result:
But I still get this error when I try to run the OpenCV install command:
What else do I need to do?
Will an upgrade to Ubuntu Studio 13.xx solve this problem (or compound it)?
