156
In my terminal prompt definition in my .bashrc file, among other things, I have this snippet of code:
${debian_chroot:+($debian_chroot)}
What does this do, and do I need it?
chaos
  • 28,186
fouric
  • 4,698
The important part to answer this question is this snippet from /etc/bash.bashrc:
if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then
    debian_chroot=$(cat /etc/debian_chroot)
fi
It means if the variable $debian_chroot is empty and the file /etc/debian_chroot exists and is readable the variable is set to the content of the file.
Now what is this for? The file /etc/debian_chroot is when you have a chrooted debian system inside another debian system (ubuntu is based on debian). So this is for a better overview. To distinguish whether you are in the chroot or not.
When you have a chroot of another system for example in /srv/nfs4/netboot/ you can set a name for this chroot in /srv/nfs4/netboot/etc/debian_chroot (in my case it's a nfs4 pxe netboot drive):
user@host:~# echo "netboot" >/srv/nfs4/netboot/etc/debian_chroot
And then when you chroot inside:
chroot /srv/nfs4/netboot/
Your prompt looks like this:
(netboot)user@host:~#
chaos
  • 28,186
89
Generally, ${var:+value} means:
if $var is defined and not null; then use 'value'; else do nothing
The debian_chroot variable is defined in /etc/bash.bashrc file. It takes the content of /etc/debian_chroot file if this file exists and is readable. By default this file doesn't exists.
For more details, see:
Now, to understand better what exactly it is happening there, do the following in terminal:
radu@Radu:~$ PS1='${var:+($var)}\u@\h:\w\$ '
radu@Radu:~$ var="test"
  V
(test)radu@Radu:~$ var=""
radu@Radu:~$ var="and so on"
(and so on)radu@Radu:~$
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
21
If the environment variable $debian_chroot exists and is not empty ${debian_chroot:+($debian_chroot)} is replaced by ($debian_chroot) (that is the value of $debian_chroot with parens around it).
$debian_chroot is set in /etc/bash.bashrc to the contents of /etc/debian_chroot if that file exists (it doesn't by default) and $debian_chroot doesn't have a value yet.
${debian_chroot:+($debian_chroot)} is usually used to define your Bash prompt, for example
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
As the name suggests you can use this variable to indicate which chroot you are in by placing etc/debian_chroot into your chroot root folders.
If you don't know what a chroot is chances are you don't need that ;-) But you still may abuse it to include some other information into your Bash prompt
By default it doesn't do anything.
If you never need to use debian_chroot then it's a handy place to put the time the command prompt was displayed by using:
export PROMPT_COMMAND='debian_chroot=$(date +%r)'
Type this in your terminal and watch your command prompt change with the time:
rick@alien:~$ export PROMPT_COMMAND='debian_chroot=$(date +%r)'
(09:14:59 PM)rick@alien:~$
After the time is set once, to get a running clock which updates every second use:
while sleep 1;do tput sc;tput cup $(($(tput lines)-1)) 1;printf `date +%r`;tput rc;done &
