I have a VHS capture device ecap303 from climaxdigital used on windows 7 i am new to ubuntu but have used the command lsusb with the device connected and come up with
ID EBIA : 2861 EMPIA TECH INS
i understand that a driver for this device is written into ubuntu 12.10 but what software do i need to use the device to copy vhs tapes and make a dvd copy eg could i use mplayer or vlc media player
i hope you can help or suggest a better capture device that might be better
i have tried tvtime and can see video both from a vcr and from a freesat box but can not get sound despite trying the recommended steps in the reply can you make any other suggestions
malcolm@malcolm-Inspiron-One-19A:~$ ls -l /dev/video*
crw-rw----+ 1 root video 81, 0 Nov 18 17:22 /dev/video0
crw-rw----+ 1 root video 81, 1 Nov 18 17:25 /dev/video1
malcolm@malcolm-Inspiron-One-19A:~$ tvtime --device=/dev/video1 | arecord -D hw:1,0 -r 48000 -c 2 -f S16_LE | aplay
Running tvtime 1.0.2.
Reading configuration from /etc/tvtime/tvtime.xml
Reading configuration from /home/malcolm/.tvtime/tvtime.xml
Recording WAVE 'stdin' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
Playing WAVE 'stdin' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
mixer: find error: Success
mixer: Can't open mixer default, mixer volume and mute unavailable.
mixer: Can't open device default/Line, mixer volume and mute unavailable.
videoinput: Aspect ratio: 0.915254
Thank you for using tvtime.
thanks regards malc
tvtime without audio request
videoinput: Driver won't tell us its norm: Invalid argument
videoinput: Can't get tuner info: Inappropriate ioctl for device
Your capture card driver: uvcvideo [Integrated_Webcam_1.3M/usb-0000:00:1d.7-2/197895]
does not support full size studio-quality images required by tvtime.
This is true for many low-quality webcams.  Please select a
different video device for tvtime to use with the command line
option --device.
retrying with: /dev/video1
Found "USB Device 0xeb1a:0x2861 : USB Audio (hw:1,0)"
tvtime with audio request
malcolm@malcolm-Inspiron-One-19A:~$ tvtime | arecord -D hw:1,0 -r 48000 -c 2 -f S16_LE | aplay -
option --device.
I have tried as suggested and still get the error messages copied above but ofcourse without the referance to my internal web-cam but still no sound i wonder if my capture device will work with ubuntu
regards
regards malcolm
Eric Carvalho
  • 55,453
As I mentioned in a comment to this question, this answer will be modified depending on the results of @malcolmelliot in order to provide the right support for his issues. (Sorry, comments are too limited.
Step 1 - Finding the video device.
Ok, first we need to make sure that tvtime is using the proper device to gather both audio and video. Remember that you can have 2 or more video devices, some of them won't embed audio (like webcams) and some yes.
You are receiving an error message which includes the next portions of text:
option --device.
Please note that the error message clearly refers to your "Integrated_Webcam_1.3M/usb-0000:00:1d.7-2/197895" which is -indeed- your computer's webcam. (maybe a laptop embedded webcam? based on the 1.3M data)
So we need to check how many devices we have in our system in order to run some testing with'em. In order to know this information we'll drop the next command in a terminal:
ls -l /dev/video*
Results should be like this:
geppettvs@DYLAN:~$ ls -l /dev/video*
crw-rw----+ 1 root video 81, 0 2012-04-17 19:53 /dev/video0
crw-rw----+ 1 root video 81, 1 2012-04-17 19:53 /dev/video1
crw-rw----+ 1 root video 81, 2 2012-04-18 17:54 /dev/video2
geppettvs@DYLAN:~$
In my case, I have 3 video devices, of which one of them is the USB TV Tuner that I use for watching/recording live TV Shows/VTR/VCR/RF-DVD/Video converter and other RF Signals.
You should check any of them and make notes of your results in order to continue. Simply run your testing via tvtime --device=/dev/video0 in a terminal. do it also for tvtime --device=/dev/video1 (which may result in an error as we see that this device is your webcam) and other instances like tvtime --device=/dev/video2, tvtime --device=/dev/video3, etc.
When you find the exact tvtuner device, make sure you use it to follow the next process.
Step 2 - Gathering both audio and video in the same stream.
Now, we need to make sure you can gather both audio and video in the same stream. If you are dropping tvtime in a terminal and getting video with no audio, then we need to instruct the sound system to get the audio and reproduce it simultaneously. This can be achieved by dropping in a terminal the next command:
tvtime --device=/dev/videoX | arecord -D hw:1,0 -r 48000 -c 2 -f S16_LE | aplay -
Please note that you should replace /dev/videoX with the proper device you found in the previous step.
This will result in both audio and video synced and embedded in the same stream. If so, then we can continue with the capture steps.
Please inform if you succeed in order to continue.
Good luck!
