What if I want to write a script that switches audio output? How can it be done under Ubuntu?
(There is a related question on Ask Ubuntu: How to switch between headphones and speakers manually)
Here is the output of my amixer -c 0 in case it is needed:
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 52 [81%] [-12.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch penum
Playback channels: Front Left - Front Right
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 0 [0%] [-64.00dB] [on]
Front Right: Playback 0 [0%] [-64.00dB] [on]
Simple mixer control 'Bass Speaker',0
Mono:
Front Left: Playback 64 [100%] [0.00dB] [off]
Front Right: Playback 64 [100%] [0.00dB] [off]
Simple mixer control 'PCM',0
Capabilities: pvolume penum
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Mic Boost',0
Capabilities: volume penum
Capture channels: Front Left - Front Right
Limits: 0 - 3
Front Left: 3 [100%] [30.00dB]
Front Right: 3 [100%] [30.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined penum
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Beep',0
Mono:
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch penum
Limits: Capture 0 - 31
Front Left: Capture 22 [71%] [16.50dB] [on]
Front Right: Capture 22 [71%] [16.50dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Internal Mic',0
Mono:
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
