I've got three partitions on my system, and I accidentally removed a shortcut to the first Ubuntu partition from the Launcher. How do I put it back?
(At least, I assume it was a shortcut, as the partition is still here. They're called shortcuts in Ubuntu, right?)
Also, is there a way to rename my drives? I keep getting confused as to which drive is which.
Now, if you want to reset the settings, run this command in a terminal:
gsettings reset com.canonical.Unity.Devices blacklist
Also works with Ubuntu 14.04 LTS.
Source: How can I remove launcher drive icons?
galeb
No, they are called launcher desktop files ( Where are the Unity Launcher .desktop files? )
Open the disc from within Nautilus and the desktop launcher will be back. All you then need to do is rightclick and fix it to the launcher.
Also see:
You can label discs:
You can also do this from the properties option when rightclicking the disc.
Rinzwind
  • 309,379
