I would like to right click on an wav-audio file in Nautilus or Dolphin and convert it to a FLAC-audio file that way with the highest possible loss less compression.
Asked
Active
Viewed 444 times
You can use flac tool. To install it from terminal you can use the following command:
sudo apt-get install flac
After the installation, you can convert .wav files info .flac files as follow (compression level varies from 0 to 8 - 8 being the best):
flac -8 source.wav destination.flac
Now you have to put the above command in a small bash script, then see, for example, this answer to know how to add it in the right click context menu in Nautilus.
Radu Rădeanu
- 174,089
- 51
- 332
- 407
