I have a problem with my network adapter after upgrading from 13.04 to 13.10. The adapter works for literally several seconds after I establish the connection but then it looks as if it got clogged somehow.
This is what I see amongst my devices:
~$ lspci | grep -i wireless
02:00.0 Network controller: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter (rev 01)
~$ uname -a
Linux bubek 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:12:00 UTC 2013 i686 i686 i686 GNU/Linux
~$ lsmod | grep 80211
lib80211_crypt_tkip    17387  0
lib80211               14040  2 wl,lib80211_crypt_tkip
cfg80211              401436  1 wl
Now, how does is behave. Let's assume I connect to my wireless network and straight after I get connected I ping the default gw:
~$ ping 10.1.0.1
PING 10.1.0.1 (10.1.0.1) 56(84) bytes of data.
64 bytes from 10.1.0.1: icmp_seq=1 ttl=64 time=226 ms
64 bytes from 10.1.0.1: icmp_seq=4 ttl=64 time=222 ms
64 bytes from 10.1.0.1: icmp_seq=7 ttl=64 time=260 ms
64 bytes from 10.1.0.1: icmp_seq=11 ttl=64 time=265 ms
64 bytes from 10.1.0.1: icmp_seq=16 ttl=64 time=117 ms
From 10.1.0.16 icmp_seq=45 Destination Host Unreachable
From 10.1.0.16 icmp_seq=46 Destination Host Unreachable
What has happened over here? Is there any possibility I can get it working? The only way I could write that post was that I used my phone and USB tethering :)
Thanks for any tips in advance!
jane
  • 23
Please try:
sudo apt-get purge bcmwl-kernel-source
sudo modprobe -rv wl
sudo modprobe -v brcmsmac
if there are any errors please continue with the commands then reboot. your wireless should be working now.
Wild Man
  • 8,327
First of all, check your current driver. You can do this by typing sudo lshw > hw_info in a terminal.
Scroll to Wireless interface. It should show your current driver and the version used.
        *-network
            description: Wireless interface
            product: BCM4313 802.11bgn Wireless Network Adapter
            vendor: Broadcom Corporation
            physical id: 0
            bus info: pci@0000:25:00.0
            logical name: eth1
            version: 01
            serial: ec:55:f9:2a:d3:58
            width: 64 bits
            clock: 33MHz
            capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
            configuration: broadcast=yes driver=wl0 driverversion=5.100.82.112 ip=192.168.1.110 latency=0 multicast=yes wireless=IEEE 802.11
            resources: irq:19 memory:d4000000-d4003fff
You can see from the last line, that I am using wl0 driver version 5.100.82.112.
There are several drivers to choose from (Official Documentation). You can switch to brcmsmac or use the 5.100 version of wl0 which has so far worked without any problems by following these instructions.
Eero Aaltonen
  • 1,424
  • 13
  • 33
