I am having the exact same issue as in this question but none of the answers worked for me.
For instance, trying this answer I get this error:
a@b:~$ cd /usr/bin
a@b:/usr/bin$ sudo cp dropbox dropbox1
[sudo] password for a:
cp: cannot stat `dropbox': No such file or directory
a@b:/usr/bin$
Is there a way to fix this?
Reinstalling and selecting "Start Dropbox on System Startup" worked as in darent's answer.
Zeynel
  • 297
Just open the gnome-session-properties utility running in a terminal:
And add an entry, simply called dropbox with the command to start it. These are my settings:
Install Dropbox as follows :
sudo apt-get install nautilus-dropbox
Then while installing, Check on adding the panel Icon.
Right click on the panal Icon and select Preferences. Check on startup option.
Or with the present dropbox;
Open the application Startup Applications
Click on Add button.
Then in the Name field, Type Dropbox
In the Command field type dropbox start -i
In Comment field type whatever you want. Doesn't matter if it is empty.
Then click on Add and close application
