Just after an update from Ubuntu 10.10 to 11.04 and a restart, Ubuntu freeze at startup on a dialog saying: "It seems that you do not have the hardware required to run Unity. Please choose Ubuntu Classic", etc.
I can not click the "Close" button. I can not switch either to another tty.
Any idea how to figure out what happen?
The error means that your 3d graphics are not enabled for Unity to work, OK the error message and go into Classic Desktop and install your 3rd party graphics for nvidia or ati (if that's what you have), then on next boot Unity should work fine...
If it seems you cant use the keyboard and mouse, then, Hold ALT + PrintScreen Keys and type R E. These magic keys will help you to get out of the Frozen Error Box and move into the console. Now Press ALT + F2 to Drop to shell.
Login with your username and password
execute the command, "sudo apt-get update"
execute the command, "sudo apt-get dist-upgrade"
Wait for the operations to complete . Make sure that the downloaded packages are getting installed. If by chance, it fails to download a package, better remove that package and re-run the "dist-upgrade". repeat this till it gets done.
execute "sudo update-grub". Verify that the grub updates its menu with the recent kernel version (2.6.38.x)
Now restart the computer. This should fix the issue
In case you get the same error after re-boot, drop to shell by following the sequence said above. remove the following packages, unity and restart.
