I'm new with Ubuntu so I don't understand most of it. A few days ago, everytime that I start the computer, I have a prompt box saying that my disk is full and I have the option to check the disk with the Disk Analyzer.
But since I don't have any idea of what to delete I don't want to touch anything. I started checking my user folder and delete everything that wasn't useful there but I don't have much. What else should I do?
Cheers.
MrThompson
  • 55
I'd check what's lurking in your Downloads folder. That's typically the #1 offender when it comes to low disk space.
Clear your browser cache manually e.g. ~/.mozilla/firefox/Cache or ~/cache/google-chrome/Default/Cache. This can free up 1GB sometimes.
You can also run from a command line sudo apt-get purge to remove old configuration files then go into Software Center or Synaptic and select apps you know you don't use.
The Disk Usage Analyzer is available under Ubuntu > Accessories > Disk Usage Analyzer. It shows which files and folders take up the most space.
Removing the old kernel is explained at How do I remove old kernel versions to clean up the boot menu? and can make space.
K7AAY
  • 17,705
You can install Ubuntu Tweak. It has a Janitor to help cleaning cache, old configs and unnecessary package.
sudo add-apt-repository ppa:tualatrix/ppa
sudo apt-get update
sudo apt-get install ubuntu-tweak
Krypton
  • 171
