-1
I need to install any form of Texas Hold Em' on a Lubuntu Live USB that doesn't have persistence.
I was able to download PokerStars.net by emulating the .exe (a windows type file) using WINE for Linux (Lubuntu). But, when I try to install, I have no room. The only place on the Live USB is in the root folder which is set to read-only.
Is there any way I can change the read only properties of the Live USB while it's in use?
So, to recap. I am running Lubuntu 13.04 and can't start in Persistent mode. When I start normally everything worked fine. I proceeded to Chromium and successfully downloaded Wine and the Pokerstars.exe. I right clicked the downloaded fiel then clicked Wine, the installer loaded fine. There are about 8 different disk icons and only the one containing system files is active.
Is there any way I can use the terminal to install it to Root.
Braiam
  • 69,112
No. You copied Ubuntu in a read-only fashion into your drive. While is read-only, all the changes will be lost. That you have already noticed when you try to install stuff into the drive.
Then change it to persisten mode or use the method to install Ubuntu into the USB. Otherwise you will be into a standstill.
Good, seems that WINE will not be a problem once you have installed Ubuntu into the USB.
Is a read-only filesystem, until you make it read-write as I mentioned above, there is no way to do so.
without having to buy another USB to install it to
You can use your already created drive.
Braiam
  • 69,112
