I accidentally deleted xorg.conf.original-0; xorg.conf.fglrx xorg.conf.fglrx-0-1, after I tried to install fglrx drivers on the graphics card, which in fact worked on 13.04 and now as I went to 13.10 has not worked.
      Now I can just switch to a new TTY with:  Ctrl + Alt + F2
I found this which is for nVidia cards
TO install the fglrx drivers for graphic card I used this tutorial
Is there any possibility that I can recover, replace, rebuilb that xorg.conf.original-0, and if exists any possibility where I could start from.
Cester Nilap
  • 79
First terminate the X using:
sudo /etc/init.d/gdm stop
Then reconfigure you're driver using:
sudo dpkg-reconfigure xserver-xorg
And restart GUI:
sudo /etc/init.d/gdm start
FRED99
  • 109
finally I managed to make GUI with this complete guide(Fix catalyst driver in Ubuntu 13.04 / 13.10), but now there's another problem: When I try to enter my password and login to Unity (normal without ctrl+alt+f1), is triyng to enter the Unity user interface but with no result(black screen) and kicks me out again to login screen.
I said I fix the problem because I can connect in Unity only with ctrl + alt + f1 then sudo startx command.
Cester Nilap
  • 79
