I upgraded my Ubuntu to 13.10 and now I can't hear any sounds.
I checked on alsamixer that voices are on. For example, I can't hear any Youtube videos.
I also lost my sound when upgrading to 13.10.
To fix it, I ran this in Terminal (Ctrl+Alt+T):
sudo alsa force-reload
Did a restart, and everything was working perfectly.
I got mine working when I looked at this document:
The issue was that I needed to add some permissions to my user. Easy to tell if that's the fix because aplay -l will say no soundcards but sudo aplay -l lists some. This was my fix:
sudo usermod -aG audio,video,pulse,pulse-access frew
this worked for me How do I change which audio jacks are used for input and output?
or make this in to a hda-mods.py and put it in /etc folder because on sudo python run.py all the sound muted just unmute the sound then save it
If you want to keep your changes permanently, don't close HDA Analyzer yet. Instead, click "Exp" (Export) at the bottom-left and use Save As to write the python script to a file. Now copy that file to something like /etc/hda-mods.py and edit /etc/rc.local as root (e.g. using gksudo gedit /etc/rc.local) and add the line python /etc/hda-mods.py right before the exit 0 line, then save it and reboot. Your changes should survive.
#!/usr/bin/env python
import os
import struct
from fcntl import ioctl
def __ioctl_val(val):
# workaround for OverFlow bug in python 2.4
if val & 0x80000000:
return -((val^0xffffffff)+1)
return val
IOCTL_INFO = __ioctl_val(0x80dc4801)
IOCTL_PVERSION = __ioctl_val(0x80044810)
IOCTL_VERB_WRITE = __ioctl_val(0xc0084811)
def set(nid, verb, param):
verb = (nid << 24) | (verb << 8) | param
res = ioctl(FD, IOCTL_VERB_WRITE, struct.pack('II', verb, 0))
FD = os.open("/dev/snd/hwC0D0", os.O_RDONLY)
info = struct.pack('Ii64s80si64s', 0, 0, '', '', 0, '')
res = ioctl(FD, IOCTL_INFO, info)
name = struct.unpack('Ii64s80si64s', res)[3]
if not name.startswith('HDA Codec'):
raise IOError, "unknown HDA hwdep interface"
res = ioctl(FD, IOCTL_PVERSION, struct.pack('I', 0))
version = struct.unpack('I', res)
if version < 0x00010000: # 1.0.0
raise IOError, "unknown HDA hwdep version"
# initialization sequence starts here...
set(0x0e, 0x300, 0x6080) # 0x0e036080 (SET_AMP_GAIN_MUTE)
os.close(FD)
