i'm kinda new to linux. last night i tried upgrading from 13.04 to 13.10 but i got the "could not calculate" error. i read this question and found this error in the main log: Dist-upgrade failed: 'E:Unable to correct problems, you have held broken packages.'
and here's a list of my broken packages :
  Broken libwayland-client0:amd64 Conflicts on libwayland0 [ amd64 ] < 1.0.5-0ubuntu1 > ( libs ) (< 1.1.0)
Broken libpam-systemd:amd64 Conflicts on libpam-xdg-support [ amd64 ] < 0.2-0ubuntu2 > ( admin )
Broken cups-filters:amd64 Conflicts on ghostscript-cups [ amd64 ] < 9.07~dfsg2-0ubuntu3.1 > ( text )
Broken libharfbuzz0a:amd64 Breaks on libharfbuzz0 [ amd64 ] < 0.9.13-1 > ( libs )
Broken libunity-scopes-json-def-desktop:amd64 Conflicts on libunity-common [ amd64 ] < 6.90.2daily13.04.05-0ubuntu1 > ( gnome ) (< 7.0.7)
Broken libunity-scopes-json-def-desktop:amd64 Conflicts on libunity-common [ i386 ] < none > ( none ) (< 7.0.7)
Broken libaccount-plugin-generic-oauth:amd64 Conflicts on account-plugin-generic-oauth [ amd64 ] < 0.10bzr13.03.26-0ubuntu1.1 > ( gnome ) (< 0.10bzr13.04.30)
Broken libaccount-plugin-generic-oauth:amd64 Breaks on account-plugin-generic-oauth [ amd64 ] < 0.10bzr13.03.26-0ubuntu1.1 > ( gnome ) (< 0.10bzr13.04.30)
Broken python3-aptdaemon.pkcompat:amd64 Breaks on libpackagekit-glib2-14 [ amd64 ] < 0.7.6-3ubuntu1 > ( libs ) (<= 0.7.6-4)
Broken libsnmp-base:amd64 Breaks on libsnmp15 [ amd64 ] < 5.4.3~dfsg-2.7ubuntu1 > ( libs ) (< 5.7.2~dfsg-5)
Broken libunity-core-6.0-8:amd64 Conflicts on unity-common [ amd64 ] < 7.0.0daily13.06.19~13.04-0ubuntu1 > ( gnome )
Broken python3-uno:amd64 Conflicts on python-uno [ amd64 ] < 1:4.0.4-0ubuntu1 > ( python )
Broken unity-scope-home:amd64 Conflicts on unity-lens-shopping [ amd64 ] < 6.8.0daily13.03.04-0ubuntu1 > ( gnome )
Broken xserver-xorg-video-mach64:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
Broken usb-modeswitch-data:amd64 Breaks on usb-modeswitch [ amd64 ] < 1.2.3+repack0-1ubuntu3 > ( comm ) (< 1.2.6)
Broken unity-gtk2-module:amd64 Conflicts on appmenu-gtk [ amd64 ] < 12.10.3daily13.04.03-0ubuntu1 > ( libs )
Broken xserver-xorg-video-intel:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
Broken xserver-xorg-video-r128:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
Broken unity-gtk3-module:amd64 Conflicts on appmenu-gtk3 [ amd64 ] < 12.10.3daily13.04.03-0ubuntu1 > ( libs )
Broken xserver-xorg-video-nouveau:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
Broken xserver-xorg-video-cirrus:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
Broken libbamf3-1:amd64 Depends on bamfdaemon [ amd64 ] < 0.4.0daily13.06.19~13.04-0ubuntu1 -> 0.5.1+13.10.20131011-0ubuntu1 > ( libs ) (= 0.4.0daily13.06.19~13.04-0ubuntu1)
Broken bzr-gtk:amd64 Depends on bzr [ amd64 ] < 2.6.0~bzr6571-4ubuntu2 -> 2.6.0-3ubuntu1 > ( devel ) (< 2.6.0)
Broken libgphoto2-6-dev:amd64 Conflicts on libgphoto2-2-dev [ amd64 ] < 2.4.14-2 > ( libdevel )
Broken activity-log-manager:amd64 Conflicts on activity-log-manager-common [ amd64 ] < 0.9.4-0ubuntu6.2 > ( utils )
Broken libgjs0d:amd64 Conflicts on libgjs0c [ amd64 ] < 1.34.0-0ubuntu1 > ( libs )
Broken libgtksourceview-3.0-0:amd64 Depends on libgtksourceview-3.0-common [ amd64 ] < 3.6.3-0ubuntu1 -> 3.8.2-0ubuntu1 > ( libs ) (< 3.7)
Broken gnome-pie:amd64 Depends on libbamf3-1 [ amd64 ] < 0.4.0daily13.06.19~13.04-0ubuntu1 > ( libs )
Broken libunity-core-6.0-5:amd64 Depends on unity-services [ amd64 ] < 7.0.0daily13.06.19~13.04-0ubuntu1 -> 7.1.2+13.10.20131014.1-0ubuntu1 > ( gnome ) (= 7.0.0daily13.06.19~13.04-0ubuntu1)
Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-cirrus [ amd64 ] < 1:1.5.2+git20130108.e2bf5b25-0ubuntu0sarvatt > ( x11 )
Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-intel [ amd64 ] < 2:2.99.904+git20131009.b9ad5b62-0ubuntu0sarvatt~raring > ( x11 )
Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-nouveau [ amd64 ] < 1:1.0.9+git20130730.300c5a32-0ubuntu0sarvatt~raring > ( x11 )
Broken xserver-xorg-video-ati:amd64 Depends on xserver-xorg-video-r128 [ amd64 ] < 6.9.1+git20130104.24f28a78-0ubuntu0sarvatt > ( x11 )
Broken xserver-xorg-video-ati:amd64 Depends on xserver-xorg-video-mach64 [ amd64 ] < 6.9.4+git20130104.80e62cc1-0ubuntu0sarvatt > ( x11 )
Broken libxi6:amd64 Breaks on xserver-xorg-core [ amd64 ] < 2:1.13.4~git20130508+server-1.13-branch.10c42f57-0ubuntu0ricotz~raring -> 2:1.14.3-3ubuntu2 > ( x11 ) (< 2:1.14)
Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-ati [ amd64 ] < 1:7.1.99+git20130730.6a278369-0ubuntu0sarvatt~raring -> 1:7.2.0-0ubuntu10 > ( x11 )
Broken xserver-xorg-video-ati:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
thats a lot of stuff ... do i have to remove them one by one ? will removing them cause any issue ? do i have to install them one by one again after the upgrade ?
EDIT: apparently it has something to do with AMD proprietary binaries ... i think
MHB
  • 61
As ZiglioNZ says, the first thing you need to do is remove the xorg-edgers repo:
sudo apt-get install ppa-purge
sudo ppa-purge xorg-edgers
One of my laptops worked after this. However on another laptop this didn't seem to fix the problem. Checking the log file /var/log/dist-upgrade/main.log I noticed that the error hadn't changed, I was still seeing a failure like:
2013-10-28 14:38:03,043 DEBUG Installing 'xserver-xorg-video-all' (Distro KeepInstalledPkgs rule)
2013-10-28 14:38:03,518 ERROR Dist-upgrade failed: 'E:Unable to correct problems, you have held broken packages.'
So I simply uninstalled the offending package and tried the upgrade again:
sudo apt-get remove xserver-xorg-video-all
sudo do-release-upgrade
and the upgrade was able to continue successfully this time.
Once the upgrade was complete, I then had a working system but apparently no X driver. So the first thing I did after login was add the xorg-edgers ppa back in and install the necessary driver:
sudo apt-add-repository ppa:xorg-edgers
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install nvidia-331
Try this:
See also this. It seems to be working for me, I'm in the middle of the upgrade.
ZiglioUK
  • 166
