I'm trying to upgrade my Kubuntu Wily 15.10 computer but it fails.
I'm doing this:
$ sudo do-release-upgrade -m desktop
This is what I get:
Calculating the changes
Could not calculate the upgrade
An unresolvable problem occurred while calculating the upgrade.
This can be caused by:
* Upgrading to a pre-release version of Ubuntu
* Running the current pre-release version of Ubuntu
* Unofficial software packages not provided by Ubuntu
If none of this applies, then please report this bug using the
command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal.
I found this on /var/log/dist-upgrade/main.log:
2016-04-29 10:29:09,024 DEBUG need_server_mode(): run in 'desktop' mode, (because of key deps for 'kubuntu-desktop')
2016-04-29 10:29:16,112 DEBUG Installing 'xserver-xorg-video-all' (Distro KeepInstalledPkgs rule)
2016-04-29 10:29:16,559 ERROR Dist-upgrade failed: 'E:Unable to correct problems, you have held broken packages.'
2016-04-29 10:29:16,560 DEBUG abort called
2016-04-29 10:29:16,576 DEBUG openCache()
2016-04-29 10:29:16,576 DEBUG failed to SystemUnLock() (E:Not locked)
2016-04-29 10:29:20,464 DEBUG /openCache(), new cache size 78719
2016-04-29 10:29:20,464 DEBUG enabling apt cron job
What can I do?
