Simple question but hard answer, i searched around in Google a solution to make a dynamic widget to control and see the volume with Awesome Window manager but i can't find a working solution.
Any one got a solution to this ?
I simply followed the tutorial at http://awesome.naquadah.org/wiki/Volume_control_and_display and it worked. However, volume control was only via keyboard. Is this what you were looking for?
I should note that I'm on debian (testing) which I think uses awesome 3.4.
-- Update: After some testing out, I found http://awesome.naquadah.org/wiki/Farhavens_volume_widget, which has mouse controls (scroll mouse to control volume, and click to toggle mute). Following the tutorial works on my box.
I'd like to mention following implementations just in case somebody is interested to have a volume control widget compatible with Awesome WM 4+:
From left to right:
All three widgets support mouse control: scroll up/down - increases/decreases volume, click - toggles mute.
If you have media keys you can use this
awful.key({}, "XF86AudioRaiseVolume", function () awful.util.spawn("amixer -D pulse sset Master 2%+", false) end),
awful.key({}, "XF86AudioLowerVolume", function () awful.util.spawn("amixer -D pulse sset Master 2%-", false) end),
awful.key({}, "XF86AudioMute", function () awful.util.spawn("amixer -D pulse sset Master toggle", false) end),
in globalkeys in your rc.lua script
volumeicon worked out of the box for me. Note that this is not an AwesomeWM widget but a standalone project written in C. The advantage of this over the Awesome widgets are:
If you'd prefer a pure Lua Awesome widget, here is a list of available ones:
