15
I have a DVD which I can open in Windows, but in my Ubuntu 12.04 installation I cannot any more. I receive this error:
Unable to mount UDF Volume
Error mounting: mount: block device /dev/sr0 is write-protected, mounting read-only
mount: wrong fs type, bad option, bad superblock on /dev/sr0,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
What should I do to open it? Do I need to install anything?
wxs
  • 107
M N
  • 165
Open the terminal and try mounting the DVD with:
sudo mount -t udf /dev/sr0 /cdrom
The argument following the -t is used to indicate the filesystem type, which in this case is udf. UDF or Universal Disk Format is an operating-system-independent file system commonly used on DVD and other digital media.1
1https://en.wikipedia.org/wiki/UDF
karel
  • 122,292
  • 133
  • 301
  • 332
Not all DVDs are really udf, if the -t udf doesn't work (wrong superblock) try:
sudo mount -t iso9660 /dev/sr0 /cdrom
that is after sudo mkdir /cdrom so the /cdrom directory exists.
~$ sudo mount -t udf /dev/sr0 /cdrom
       try `dmesg | tail`  or so
~$ sudo mount -t iso9660 /dev/sr0 /cdrom
~$ ls /cdrom
autorun.inf  casper  EFI      isolinux    pics  preseed             ubuntu
boot         dists   install  md5sum.txt  pool  README.diskdefines  wubi.exe
*Yet it is a DVD+R
user.dz
  • 49,176
In my case (same case, DVDs playing in windows but not on Linux) I resolved it installing libdvdcss.
sudo apt install libdvd-pkg  # libdvdcss in Archlinux
Besides libdvdcss I would check also that is installed libdvdread and libdvdnav.
These libraries seem to be needed to play encrypted DVDs (and I wasn't aware that the DVDs were encrypted, but they use Content Scramble System (CSS) keys that needed to be retrieved through the libdvdcss library).
Pablo Bianchi
  • 17,371
carlos
