root@ip-10-194-97-94:~# apt-get install uwsgi
Reading package lists... Done
Building dependency tree
uwsgi: Depends: uwsgi-python2.6 (>= 0.9.6.5-0ubuntu1~lucid1) or
uwsgi-python3.1 (>= 0.9.6.5-0ubuntu1~lucid1)
E: Broken packages
Asked
Active
Viewed 1,611 times
Jorge Castro
- 73,717
timger
- 121
Original text: A melhor forma seria
Translated using Google Translate: The best way would be
sudo add-apt-repository ppa:uwsgi/release
sudo apt-get update
sudo apt-get install uwsgi-python
jokerdino
- 41,732
uwsgi is not in the default repositories. You need to add a PPA (Personal Package Archive) and update your sources:
sudo apt-get update
Lekensteyn
- 178,446
uWSGI is not well packaged. You must either install uwsgi-python or uwsgi-python3. All of the other packages are marked as Conflicts, which is completely confusing and assuredly wrong.
Gabe Mc
- 111
