I can't get the wireless card on my dell mini 1010 to work. I need the driver, but I am unable to access the internet from the dell mini 1010. I am able to access it with my lenovo, and I have ubuntu 12.04.3 on it as well. so is there a way to download the driver as a file? That way I can transfer it via a flash drive and then load it through terminal, or something.
I wanted to add that I do not have access to a wired connection, hence needing to transfer between computers.
Dell Mini 1010 has the BCM4312 wireless by Broadcom, also known as Dell 1397.
~$ lspci -nnk | grep -A2 Net
03:00.0 Network controller [0280]: Broadcom Corporation BCM4312 802.11b/g LP-PHY [14e4:4315] (rev 01)
    Subsystem: Dell Wireless 1397 WLAN Mini-Card [1028:000c]
That card can work with the preinstalled b43 driver, if the b43 firmware is installed, and the required firmware is contained in the linux-firmware-nonfree package.
Simply download linux-firmware-nonfree on Lenovo, transfer it to Ubuntu, and install by double clicking.
In a terminal window, run sudo modprobe b43 to load the module. Wireless should work now.
mikewhatever
  • 33,013
