I'm using English, Russian and Armenian keyboard layouts. When I'm trying to change layout it's changing "en" -> "am" -> "ru" -> "en"... I want to use Left Alt + Shift to toggle "en" and "am", and Right Alt + Shift to toggle "en" and"ru". Can you help me?
There are many shortcuts to choose to switch between keyboard layouts, but none fits with what you want.
Anyway, it can be done using a bash scripts and two custom shortcuts.
First, create the script, let's call it change_layouts:
#!/bin/bash
#script to switch between two keyboard layouts
if [ $# -ne 2 ];then
    echo "Usage: `basename $0` first_layout second_layout"
    echo "   ex: change_layouts us ru"
    exit
fi
first_layout=$1
second_layout=$2
if [ -z "$(ls -l /usr/share/X11/xkb/symbols | grep ^- | awk '{print $9}' | grep $first_layout)" ]; then
    echo "Error: Doesn't exists ant keyboard layout called '$first_layout'."
    exit
fi
if [ -z "$(ls -l /usr/share/X11/xkb/symbols | grep ^- | awk '{print $9}' | grep $second_layout)" ]; then
    echo "Error: Doesn't exists ant keyboard layout called '$second_layout'."
    exit
fi
if [ "$first_layout" = "$second_layout" ]; then
    echo "Error: The arguments (keyboard layouts) must to be different."
    exit
fi
current_layout=$(gsettings get org.gnome.libgnomekbd.keyboard layouts)
if [ "$current_layout" = "['$first_layout', '$second_layout']" ]; then
    gsettings set org.gnome.libgnomekbd.keyboard layouts "['$second_layout', '$first_layout']"
else
    gsettings set org.gnome.libgnomekbd.keyboard layouts "['$first_layout', '$second_layout']"
fi
Save the script in your ~/bin directory and don't forget to make it executable:
chmod +x ~/bin/change_layouts
Now you can test the script in terminal. Run it more times to see how it works.
Second, add your custom shortcuts. Go to System SettingKeyboardShortcutsCustom Shortcuts and follow the instructions from the below image:
add custom shortcut
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
