During a foolish attempt at installing Windows 7 alongside Ubuntu 12.10 on a separate drive for some lab work, I accidentally deleted (not formatted) the wrong disk and immediately after realizing what I had done stopped the installation. So now nothing is installed and I am left with
grub rescue>
I know my files are still there. How do I go about putting everything back in its place?
Would it be easier to continue with my plans to install Windows 7 on the right disk and recover the partitions from there?
Or should I recover my Ubuntu 12.10 system first and then attempt the Windows 7 install after with more caution?
Zanna
  • 72,312
OK, so one good thing is you stopped the install. You can now do two things: 1>Get another computer with Windows installed and connect your hard drive to it. Then go to http://www.active-undelete.com/ and try using their soft. I'm not sure it will support ext3 or ext4 type partitions but it is worth a try...
OR
2> Burn yourself a live cd/usb of http://ubuntu-rescue-remix.org and see if it works for you.
Also checkout the https://help.ubuntu.com/community/DataRecovery page. Hope the links were helpful. Tell me in comment if any of them worked.
Rohitt Vashishtha
  • 499
  • 14
