I'm having this problem after an automatic upgrade, where the only thing that is correctly loaded is the background image.
Another user experienced the exact same problem, though the cause is different (this was his post: Desktop does not show when I installed nvidia drivers!).
Consider that previously to this, I used Repair Mode, but it didn't work at all! Once I load Ubuntu in Normal Mode, the same thing happens.
Thanks in advance.
Reptile
  • 41
I used these commands to fix everything and it worked. So, here are the steps:
  1. Press Ctrl + Alt + F1
  2. Login with your username and password
  3. Run this command:
    sudo apt-get install --reinstall ubuntu-desktop
  4. Then restart the system writing this:
    sudo shutdown -r now
That would be all.
I'm not a programmer, and it's the first time I write here, so, in case something is wrong, feel free to correct or improve my message if you're an expert.
Thanks.
kiri
  • 28,986
Reptile
  • 41
