I downloaded ubuntu 12.04 lts 64bit version. Laptop already has windows 7 and installed along side windows 7. After installation, it is not showing up in boot menu. Instead it is directly booting to windows 7. Laptop supports 64 bit. I did the same thing in my pc, but it worked fine. Also after installation, in windows 7, the ext4 partition doesn't show up. Please help. Thank You
ext4 partitions will not be shown/mounted under Windows.
Ubuntu can be added to Windows bootloader by using a simple easy-to-use software EasyBCD.
Please follow the instructions provided by EasyBCD creators here.
Steps 5-7 can be omitted if you want to see GRUB for about 10 seconds. This might be useful if you want to boot into a different kernel for Ubuntu.
Download EasyBCD without registering in their website by following this link.
Disclaimer: Keep in mind, this will enable windows bootloader by default, not GRUB. If you want to keep GRUB as default bootmanager, follow the tutorial mentioned by @m-tarun.
k1chy
  • 292
