I just installed Ubuntu and love it so much, its so fast now. But I have a problem connecting to the internet.
I checked and saw I have to install the driver Broadcom STA wireless driver but every time I do try to install it it says:
Sorry, installation of this driver failed. Please have a look at the log files for
details: /var/log/jockey.log
I went to the terminal and copy and pasted the log file name. and when I did it, it said I have no permission to access this file. I checked on the forums that I have to be on a wired connection. So I plugged my laptop into my router and I got internet then tried to install the driver again. And it was loading then when it got to the end the same message popped up.
Also I have one of those little USB router things you plug into the computer and it gives you internet I have been using that but its to slow. So I want to use the one in my computer but cant.
Also I tried the command:
sudo modprobe wl
and when i type that command in it says:
FATAL: Module wl not found
Also I'm using Ubuntu 12.04
Steam gamer
  • 1,016
ngngngn
  • 111
My friend, I had the same problem and I solved like this:
  • First, uninstall the bcmwl-kernel-source
     sudo apt-get purge bcmwl-kernel-source
  • Install the firmware-b43-installer
     sudo apt-get install firmware-b43-installer
  • And the b43-fwcutter
    sudo apt-get install b43-fwcutter
  • Restart your computer
I hope that works for you =)
Installing Broadcom Wireless Drivers
You need root permission to unlock that log file Open terminal and type
  sudo gnome-control-center
You will be able to install drivers after that
Ayush
  • 101
