I'm a complete newbie to ubuntu, I've already installed and reinstalled the Broadcom driver required done a numerous amount of steps on terminal but I can't seem to get wireless working. However, my wired connection seems to work just fine.
also I have tried to follow the instructions but get stuck at step number 2 when i get told "No package dpkg is available":
1) Download the file from the link
2) sudo yum install dpkg
3) mkdir BCM43142
4) dpkg-deb -x Downloads/wireless-bcm43142-dkms-6.20.55.19_amd64.deb BCM43142
5) cd BCM43142/usr/src/wireless-bcm43142-oneiric-dkms-6.20.55.19~bdcom0602.0400.1000.0400/src/wl/sys
6) sudo yum install kernel-devel kernel-headers
7) vi wl_linux.c
8) around line 43, remove the line
include
9) save the file (:wq)
10) cd ../../..
11) make
Things should work, and you'll have a file called "wl.ko" in the current directory.
12) sudo yum remove broadcom-wl
13) sudo mkdir -p /lib/modules/3.5.2-3.fc17.x86_64/extra/wl
14) sudo cp wl.ko /lib/modules/3.5.2-3.fc17.x86_64/extra/wl
15) sudo depmod -a
16) sudo modprobe wl
I really need help :/
beckett
Hi and welcome to Ask Ubuntu!
YUM is the package manager for Red Hat and distros based on Red Hat. Ubuntu is based on Debian and uses the APT front-end for dpkg. If you are on a Ubuntu system, dpkg are already installed and working.
This is what you do:
  1. Download this file (wireless-bcm43142-dkms_6.20.55.19-1_amd64.deb)
  2. Open your terminal and run this command:
    sudo apt-get install linux-headers-generic build-essential dkms
  3. Navigate to your download folder (cd ~/Downloads) and run this command:
    sudo dpkg -i wireless-bcm43142-dkms_6.20.55.19-1_amd64.deb
  4. Then run this command to load the modul:
    sudo modprobe wl
If you still are having problems, let us know and we will help you make it work!
Nullet
  • 3,082
