I've been having this problem this whole day and it's been killing me... I'm following Dual boot Surface Pro with Ubuntu? this guide to dual boot my Microsoft Surface Pro with Ubuntu 13.04.
The main problem I have is that the WiFi doesn't work and I do not have a Ethernet port on this device. I get to the point in the guide where he installs boot-repair, the problem is that he downloads it off the internet... which I have no access too.
Just so you know, I am have Ubuntu on my device installed under a partition. I did the try and install Ubuntu option, installed it and now I'm "continuing testing", simply just trying to get Grub2 to work, so I can switch between partitions. WiFi would be a plus too, but that shouldn't be difficult once I get this out of the way.
So I've tried a few things... I downloaded the tar.gz of boot-repair on my other partition and grabbed it from there. There is absolutely no documentation that tells me how to manually compile it, so I got stuck there.
I tried to do step 7 on the tutorial, download the two .deb files and get them on to this OS from my Windows partition and manually install them using the "sudo dpkg -i package.deb" command. The .deb's installed by my internet still isn't working. Even when I double click them so I can use the Ubuntu Software Center, the install button is just grayed out.
I tried using EasyBCD on my Window partition to set up a way to access my Ubuntu Partition from boot up but I just get a WBM error and then Windows 8 boots after. I just want to get Grub2 working so I can actually tackle this WiFi issue without constantly having to boot off this annoying flash drive. Is there anyone I can get Grub2 or any way to switch between partitions working without WiFi?
I appreciate all the help, after a few beers and about 8 hours of working on this straight I'm about to throw my Surface out the window. Cheers.
Chris
