Here's an essential procedure for declaring a permanent function:
Open ~/.bashrc file in a text editor. Doesn't matter which text editor, so long as you know how to use it and so long as you open the /home/<username>/.bashrc
At the end of the ~/.bashrc declare your own function, for instance:
find_dirs(){
find "$1" -type d
Save and close the file.
The ~/.bashrc file is read every time you open interactive shell (that is new terminal tab, login via ssh, or open TTY1 or other virtual console). This will not be available in script files, because ~/.bashrc is not read for non-interactive shells. It is also not available if you run bash with --norc option.
If you want the function to be available immediately in the currently open tab, use source ~/.bashrc command.
Functions take arguments just like regular commands. For example, $1 through $9 indicate the positional parameters when you call a function. In the example above find_dirs takes one positional parameter only, and would be called as find_dirs /etc. You can also use $@ to refer to all positional parameters. Functions also accept redirection. You can call a function with find_dirs $1 > /dev/null; we also could declare it as follows:
find_dirs(){
find "$1" -type d
Note from man bash: "Functions are executed in the context of the current shell; no new process is created to interpret them". That means that you also should be aware of functions having ability to alter your shell execution environment - change variables and terminal settings.
