I want to install Kubuntu 13.04 together with Windows 7 in UEFI Mode. I installed Windows 7 first, which created the EFI boot partition.
When it come to installing Kubuntu, the installation failed when trying to install Grub-efi on sda with the error that grub-efi install to /target/ failed.
There is a simliar thread with the same problem but on 12.04:
Why 12.04 Fails to install grub-efi to /target/?
..and the solution was to use 12.10. But I'm using a newer version of (k)ubuntu.
Any Solutions here are highly welcome.
Update:
It also doesn't work with just kubuntu on the disk, so it's definitely not a dual boot issue.
Solved:
I used 12.10 and the installation succeded without any problem except that grub didn't add Windows. Fix that with boot-repair.
I found a Kubuntu Bug entry which says, that it's probably a kernel Bug in 13.04.
Rooboo
  • 63
If the installation has mostly finished, but just failed on the GRUB installation, I have two suggestions:
  • Try Boot-Repair, which should set up GRUB for you.
  • Try the USB flash drive or CD-R version of rEFInd. If that gets Linux booted, you can then install the Debian package version, which with any luck will install without error to the hard disk.
Rod Smith
  • 45,120
  • 66
  • 108
