Since installing Ubuntu 12.04, I am experiencing low performance on graphic programs, including video playbacks, etc.
As I have checked the intel driver of mine is already at its latest version. It's really occuring meanwhile playback of videos or web-flash videos (youtube, etc) OS is being logged out automatically and just display an error reporting of Xorg windows for me. I can not actually playback hd videos with the normal frame rate as well. here are some initiation of my graphic card details :
*-display:0
   description: VGA compatible controller
   product: Mobile 4 Series Chipset Integrated Graphics Controller
   vendor: Intel Corporation
   physical id: 2
   bus info: pci@0000:00:02.0
   version: 07
   width: 64 bits
   clock: 33MHz
   capabilities: msi pm vga_controller bus_master cap_list rom
   configuration: driver=i915 latency=0
   resources: irq:45 memory:f6c00000-f6ffffff memory:e0000000-efffffff ioport:efe8(size=8)
*-display:1 UNCLAIMED
   description: Display controller
   physical id: 2.1
   bus info: pci@0000:00:02.1
   version: 07
   width: 64 bits
   clock: 33MHz
   capabilities: pm bus_master cap_list
   configuration: latency=0
   resources: memory:f6b00000-f6bfffff
and the intel model:
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
Edited: A little more information :
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 12.04.3 LTS
Release:    12.04
Codename:   precise
Username Info:
Linux amir-laptop 3.2.0-53-generic-pae #81-Ubuntu SMP Thu Aug 22 21:23:47 UTC 2013 i686 i686 i386 GNU/Linux
Xorg info :
ii  xserver-xorg-video-intel               2:2.17.0-1ubuntu4.4                       X.Org X server -- Intel i8xx, i9xx display driver
Amir
  • 1,111
Follow these steps precisely!
  1. Run following command in terminal and tick all check boxes under Ubuntu Software and Updates tabs. If already ticked then leave it.
    sudo software-properties-gtk
    then update your repository:
    sudo apt-get update
  2. Install Linux Kernel 3.8.0 by selecting following packages in Synaptic:
    linux-generic-lts-raring
    linux-headers-3.8.0-30
    linux-headers-3.8.0-30-generic
    linux-headers-generic-lts-raring
    linux-image-3.8.0-30-generic
    linux-image-generic-lts-raring
    you can also install Kernel 3.8.x by executing following command:
    sudo apt-get install linux-generic-lts-raring linux-headers-3.8.0-30 linux-headers-3.8.0-30-generic linux-headers-generic-lts-raring linux-image-3.8.0-30-generic linux-image-generic-lts-raring
    Once installed execute following command to update-grub and reboot your system(be sure to select Kernel 3.8.0.30 from your grub menu):
    sudo update-grub && sudo reboot
    Before trying to 3rd step I just want you to try 4th step. If it fixes your problem then no need to install latest Xserver-Xorg packages so you can skip 3rd step.
  3. Install all -lts-raring packages for Xserver-Xorg using following command:
    sudo apt-get install libgl1-mesa-dri-lts-raring libxatracker1-lts-raring xserver-xorg-core-lts-raring xserver-xorg-input-all-lts-raring xserver-xorg-input-evdev-lts-raring xserver-xorg-input-mouse-lts-raring xserver-xorg-input-synaptics-lts-raring xserver-xorg-input-vmmouse-lts-raring xserver-xorg-input-wacom-lts-raring xserver-xorg-lts-raring xserver-xorg-video-all-lts-raring xserver-xorg-video-ati-lts-raring xserver-xorg-video-cirrus-lts-raring xserver-xorg-video-fbdev-lts-raring xserver-xorg-video-intel-lts-raring xserver-xorg-video-mach64-lts-raring xserver-xorg-video-mga-lts-raring xserver-xorg-video-modesetting-lts-raring xserver-xorg-video-neomagic-lts-raring xserver-xorg-video-nouveau-lts-raring xserver-xorg-video-openchrome-lts-raring xserver-xorg-video-r128-lts-raring xserver-xorg-video-radeon-lts-raring xserver-xorg-video-s3-lts-raring xserver-xorg-video-savage-lts-raring xserver-xorg-video-siliconmotion-lts-raring xserver-xorg-video-sis-lts-raring xserver-xorg-video-sisusb-lts-raring xserver-xorg-video-tdfx-lts-raring xserver-xorg-video-trident-lts-raring xserver-xorg-video-vesa-lts-raring xserver-xorg-video-vmware-lts-raring libxrandr-ltsq2 x11-xserver-utils-lts-raring xserver-common-lts-raring
    Why this list is so long because I ensure that you install all lts-raring packages for xserver-xorg. I recommend you to copy and paste it in terminal. It will remove already installed Xserver-Xorg packages which was meant for previous kernel. so press y when it prompts to remove such packages.. Run this command to ensure you installed all:
    sudo apt-get install --install-recommends xserver-xorg-lts-raring
  4. Now execute following commands:
    sudo apt-get autoremove
    sudo apt-get autoclean
    sudo dpkg-reconfigure -a
    sudo dpkg-reconfigure $(dpkg -l | awk '{print $2}' | grep "^xserver" | tr '\n' ' ')
    If last step shows some error, then execute these commands sudo apt-get -f install, sudo apt-get --purge remove, sudo apt-get autoremove && sudo apt-get autoclean.
    Then again try to run the command that gives you error. If still it gives you the same error then replace that command with this one: sudo dpkg-reconfigure $(dpkg -l | awk '{print $2}' | grep 'lts-raring' | tr '\n' ' ').
    Then continue to next:
    sudo update-initramfs -u
    Then restart your system again:
    sudo reboot
  5. After reboot your system should work great.
A short description of all steps mentioned above:
1st Step ensures that you'll able to download lts-raring packages.
In 2nd step you are installing a good stable kernel for your system, you are using so old kernel: 3.2.x.
3rd Step will install Xserver-Xorg packages including graphics card driver which is best supported by Kernel 3.8.0
4th Step is used to re-configure the packages installed in your system to latest kernel just you installed.
It is not that much tough, I did it without any problem. And my system works great now! If you get any problem or error at any particular step, just reply mentioning that command with the error. I'll be waiting for your reply..
Saurav Kumar
  • 15,174
