I have installed moonlight from this post here: https://askubuntu.com/a/327862/188878
the problem is, the application/website I am trying to use "requires" silverlight 5. is there anyway to trick the website into thinking I have silverlight 5 so that I can at least try it out and see if it works. the website is www.dayforcehcm.com and its so that I can do my scheduling at work. If this doesnt work, its a near deal breaker for me and ubuntu..
or is there any other sources of a silverlight alternative/way I could access this website?
thanks.
EDIT: had to remove some code because post became too long. the following code is from pipelight installed on firefox 23 running on ubuntu 13.04
checking the terminal output shows lots of errors, so perhaps this site actually is incompatible:
fixme:thread:NtQueryInformationThread info class 16 not supported yet
fixme:module:GetModuleHandleExW should pin refcount for 0x240000
fixme:urlmon:Uri_GetPropertyBSTR (0x5e61a78)->(6 0x63dee4 4)
fixme:thread:GetThreadPreferredUILanguages 48, 0x63e580, (nil) 0x63e578
fixme:time:GetCalendarInfoW Unimplemented caltype 2
fixme:time:GetCalendarInfoW Unknown caltype 56
fixme:time:GetCalendarInfoW Unknown caltype 55
fixme:time:GetCalendarInfoW Unknown caltype 49
fixme:time:GetCalendarInfoW Unknown caltype 50
fixme:time:GetCalendarInfoW Unknown caltype 51
fixme:time:GetCalendarInfoW Unknown caltype 52
fixme:time:GetCalendarInfoW Unknown caltype 53
fixme:time:GetCalendarInfoW Unknown caltype 54
fixme:time:GetCalendarInfoW Unknown caltype 21
fixme:time:GetCalendarInfoW Unknown caltype 22
fixme:time:GetCalendarInfoW Unknown caltype 23
fixme:time:GetCalendarInfoW Unknown caltype 24
fixme:time:GetCalendarInfoW Unknown caltype 25
fixme:time:GetCalendarInfoW Unknown caltype 26
fixme:time:GetCalendarInfoW Unknown caltype 27
fixme:time:GetCalendarInfoW Unknown caltype 28
fixme:time:GetCalendarInfoW Unknown caltype 29
fixme:time:GetCalendarInfoW Unknown caltype 30
fixme:time:GetCalendarInfoW Unknown caltype 31
fixme:time:GetCalendarInfoW Unknown caltype 32
fixme:time:GetCalendarInfoW Unknown caltype 33
fixme:time:GetCalendarInfoW Unknown caltype 34
fixme:time:GetCalendarInfoW Unknown caltype 35
fixme:time:GetCalendarInfoW Unknown caltype 36
fixme:time:GetCalendarInfoW Unknown caltype 37
fixme:time:GetCalendarInfoW Unknown caltype 38
fixme:time:GetCalendarInfoW Unknown caltype 39
fixme:time:GetCalendarInfoW Unknown caltype 40
fixme:time:GetCalendarInfoW Unknown caltype 41
fixme:time:GetCalendarInfoW Unknown caltype 42
fixme:time:GetCalendarInfoW Unknown caltype 43
fixme:time:GetCalendarInfoW Unknown caltype 44
fixme:time:GetCalendarInfoW Unknown caltype 45
fixme:time:GetCalendarInfoW Unknown caltype 46
fixme:time:GetCalendarInfoW Unimplemented caltype 4
fixme:time:GetCalendarInfoW Unknown caltype 57
fixme:nls:EnumTimeFormatsW Unknown time format (2)
[PIPELIGHT] Unscheduled event timer
I tried wine today, installed firefox 23, silverlight 5. Visited the website and seemed to get the same errors that pipelight got.. perhaps this is something that is wines fault then?
fixme:advapi:RegisterTraceGuidsW (0x1eb1f87, 0x1f50118, {aa087e0e-0b35-4e28-8f3a-440c3f51eef1}, 1, 0x33eaac, (null), (null), 0x1f50118,): stub
fixme:advapi:CreateProcessAsUserW 0x11c L"C:\\Program Files (x86)\\Microsoft Silverlight\\5.1.20513.0\\agcp.exe" L"agcp.exe 109 276" (nil) (nil) 1 0x00004000 (nil) (null) 0x33ee30 0x33ee20 - semi- stub
fixme:heap:HeapSetInformation (nil) 1 (nil) 0
fixme:file:K32GetMappedFileNameW (0xffffffff, 0x4015f4, 0x50e1d4, 520): stub
fixme:module:GetModuleHandleExW should pin refcount for 0x1e40000
fixme:win:GetRawInputDeviceList (pRawInputDeviceList=(nil), puiNumDevices=0x33cb54, cbSize=8) stub!
fixme:wininet:INET_QueryOption INTERNET_OPTION_PER_CONNECTION_OPTION stub
fixme:wininet:INET_QueryOption Unknown dwOption 10
fixme:wininet:INET_QueryOption Unhandled dwOption 4
fixme:urlmon:Uri_GetPropertyBSTR (0x27a6198)->(6 0x33e224 4)
fixme:process:GetNumaHighestNodeNumber (0x33ecc0): stub
fixme:thread:GetThreadPreferredUILanguages 48, 0x33e8c0, (nil) 0x33e8b8
**fixme:time:GetCalendarInfoW Unimplemented caltype 1
fixme:time:GetCalendarInfoW Unknown caltype 46**
EDIT:
Just wanted to update to say that I tried this again with the newest release of wine, winetricks, wine-gecko, and wine-mono installed and it worked flawlessly. no caltype errors, no useragent spoofing required. Had to create a 32 bit wine prefix, and installed dotnet45 using winetricks. Visited websites using firefox. for reference, this was wine 1.735, winetricks 20141130, wine_gecko 2.34, wine-mono 4.5.4. I can confirm that this now works on Ubuntu 14.04 and an up to date Arch build.
