I am running Ubuntu 12.04 on my computer. Yesterday I tried to change the splash screen according to the instructions here here.Then I installed gdm. After that I restarted the computer and the splash screen was changed. I enabled automatic login. Then I restarted again and went into windows 7 and again came back to Ubuntu.
This time Ubuntu was stuck up at a black screen with the following message:
                                    Ubuntu 12.04
                                ....*starting virtualBox kernel modules       [OK]
*stopping cold plug devices       [OK]
                                  [OK]*Stopping log initial device creation
                                  [OK]*Starting configure network device security
                                  [OK]*Starting save udev log and update rules
                                  [OK]*starting configure virtual network devices
                                  [OK]*Stopping configure virtual network devices
                                  [OK]*Stopping save udev log and update rules [OK]
                                      *Starting Network connection manager wicd
    *Starting the winbind daemon winbind                                            [OK]S
aned disabled:edit /etc/default/saned                                               [OK]S
tarting HWActivator *[done]
                               *Starting TiMidity++ALSA midi emulation...          [OK][
23.184121] usb 1-1.5:device descriptor read/64, error -32
[23.359845]usb 1-1.5:device descriptor read/64, error -32
I have reinstalled Ubuntu now, but I just want to know what caused the problem.
M.Tarun
  • 5,121
This is a hardware error you see it with some USB device. Is at random as it could get.
USB has an over-current protection, which gets triggered when power consumption from the port is too high. (Triggering this error)
You can try unplugging all devices and trying again after a minute or two.
Sources:
Braiam
  • 69,112
-1
I have installed the XCP-NG server in one laptop and my system was not booting either due to this error: USB 3-1 device descriptor read/64, error 32
I tried a lot of things. Even disconnecting the USB ports.
Until I recalled that I have removed the default SR repository for Xen. So I went to check the /etc/fstab file
[root@xcpserver2 ~]# cat /etc/fstab
LABEL=root-jvgtod    /         ext3     defaults,noatime   1  1
LABEL=swap-jvgtod          swap      swap   defaults   0  0
LABEL=logs-jvgtod    /var/log         ext3     defaults,noatime   0  2
/opt/xensource/packages/iso/XenCenter.iso   /var/xen/xc-install   iso9660   loop,ro   0  0
The default SR repository was trying to get the content of the last line. I tried to comment it and it worked!! :) I concluded that this error it also showing when there is a problem at the /etc/fstab file. I hope it helps!
So, my /etc/fstab file looks like this now and it solved the issue:
#/opt/xensource/packages/iso/XenCenter.iso   /var/xen/xc-install   iso9660   loop,ro   0  0
