I've got a small problem with sound amplification. I use the volume-buttons on my keyboard a lot (much closer than the volume button of my sound system). When I press the volume up key, the overall system sound goes beyond the 100% amplification bar. Thus, i get incredible bad sound. I really don't like that.
I've read some possibilities to fix this, but the answers are a bit messy.
So, therefore, is it possible to disable sound amplification completely? And how do I do that?
In the sound dialog box I can change the output-volume, but that's it. I can't set the max volume output.
Hope someone can help me!
There are a couple of things you can try to fix that issue. It really depends on a set of particularities of your sound card and Linux drivers. But you can try this:
  • Take a look at this question: Adjust PCM volume? The master and PCM volumes referred in that question are set with alsamixer.
  • Install pavucontrol and see if any options help: sudo apt-get install pavucontrol
Hugo Vieira
  • 1,272
