I've recently done a fresh install of Lubuntu 13 on my laptop, I immediately noticed a recurring clicking sound when it wasn't charging.
Running:
    lspci | grep -i audio
gives:
Audio device: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller (rev 04)
Some investigation led me to this question/answer: How do I fix laptop speakers popping when no sound is playing?
Running the script fixes the problem which seems to prove that it is related to power-save mode. Unfortunately I need to run the script every time I reboot.
Does anybody know of a way to make this change permanent, or if there is a better way to go about resolving this?
AndySX
  • 51
OK, I've just come across a solution that appears to work, even after a reboot. I found the solution here: http://ubuntuforums.org/showthread.php?t=1788483 but I'll paraphrase in case the link stops working.
Open terminal and type:
gksudo gedit /usr/lib/pm-utils/power.d/intel-audio-powersave
Find this line:
INTEL_AUDIO_POWERSAVE=${INTEL_AUDIO_POWERSAVE:-true}
and comment it out by putting a # in front of it like this:
# INTEL_AUDIO_POWERSAVE=${INTEL_AUDIO_POWERSAVE:-true}
Just below this line add a new line, like this:
INTEL_AUDIO_POWERSAVE=false
So now you will have:
Save the file (File > Save) and exit.
Reboot your computer.
The clicking/popping sound will be gone.
Essentially this will stop the Intel driver from putting the hardware into sleep mode. Not ideal, and hopefully a future update will fix it, but hopefully this will be of help.
AndySX
  • 51
You can use the file audio-power-save-off which consists your script to run every time your system starts. You have to add it on Startup Applications.
  • Search for Startup Applications on your dash and Run it. You can also find it in directory /usr/share/applications. Just browse it.
  • Once started, click Add button.
  • Give some name on first field, Browse for the file where you stored audio-power-save-off for the second field and again give some comment for the third field. Then Add.
  • Your script would be executed each time you starts your system.
Give it a try, hope it works for you..
Also I found this link somewhat important.
Saurav Kumar
  • 15,174
