I'm looking for a tool for Ubuntu 13.04 that can reduce the bitrate of multiple mp3 files. Does anyone happen to know such a tool?
Reducing the bit rate will involve re-encoding, which means that you'll have to create separate output files. You could use avconv from the command-line:
avconv -i input.mp3 -c:a libmp3lame -b:a 128k output.mp3
To do a whole directory of .mp3s:
for f in ./*.mp3; do avconv -i "$f" -c:a libmp3lame -b:a 128k "${f%.*}-out.mp3"; done
This will create files with -out.mp3 at the end of their names. If you want to replace your originals, you can then use mv to overwrite them (warning: this should be considered irreversible):
for f in ./*.mp3; do avconv -i "$f" -c:a libmp3lame -b:a 128k "${f%.*}-out.mp3" && mv "${f%.*}-out.mp3" "$f"; done
It might be safer to do this in two steps:
for f in ./*-out.mp3; do mv "$f" "${f%-out.mp3}.mp3"; done
You can do this to files recursively (every .mp3 in the working directory and all sub-directories):
shopt -s globstar
for f in ./**/*.mp3; do avconv -i "$f" -c:a libmp3lame -b:a 128k "${f%.*}-out.mp3"; done
for f in ./**/*-out.mp3; do mv "$f" "${f%-out.mp3}.mp3"; done
- 4,625
ffmpeg is the tool I'd use, and I'd combine it with find to find the files I wanted converting.
mkdir converted
find . -iname '*.mp3' -exec ffmpeg -i  "{}" -b 100k "{}" "converted/{}" \;
- 299,380
Try Audacity. Audacity is free, open source software for recording and editing sounds. You can use Audacity to record live audio, convert tapes and records, edit sound files, change the speed or pitch of a recording and much more.
For more info, and to download form Audacity, check out their website
Or to install just click Audacity
Source:Audacity
