After doing a good deal of digging, I found the answers and decided to post here to consolidate for others.
Answer 1. Find current sample rate of mp3
cd
To where the mp3 file is. Then type
file song.mp3
Replace "song .mp3" with the name of your file. This is based on the helpful answer here.
Answer 2. Find the lowest bitrate where voice recordings sound acceptable at
Both 64 and 32 worked for me. Since the mission here was to limit size, I went with 32 (here is a more indepth discussion on the topic).
To test which bit rate works best for you, run
avconv -i song.mp3 -c:a libmp3lame -b:a 64k test.mp3
Then play the test.mp3 file and see if you like it. Change the "64k" to different values to get different bit rates. For example change it to "128k" if you would like a higher quality but larger sized mp3.
Answer 3. Convert current files to the revised bit rate (many files at once)
Again make sure you have navigated in the terminal to the folder where you would like to change the files. Then run:
for f in ./*.mp3; do avconv -i "$f" -c:a libmp3lame -b:a 32k "${f%.*}-out.mp3"; done
You can specifcy any naming convention for the output file by modifying the "${f%.*}-out.mp3". This great code was provided from this answer. Visit it to see a more in depth answer for how you can a) preserve the original names and b) how you could run on an entire file directory.
