48
I installed the ubuntu 12.04 server edition for my server pc . i had installed lamp server. i need to change the var/www location to my secondary hard disk location. i was configured so many time to at gedit /etc/apache2/sites-available/default here is my code
<VirtualHost *:80>
    ServerAdmin webmaster@localhost
    #DocumentRoot /var/www
    DocumentRoot /media/myserver/
    <Directory />
        Options FollowSymLinks
        AllowOverride None
    </Directory>
    #<Directory /var/www/>
        <Directory /media/myserver/>
        Options Indexes FollowSymLinks MultiViews
        AllowOverride None
        Order allow,deny
        allow from all
    </Directory>
    ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
    <Directory "/usr/lib/cgi-bin">
        AllowOverride None
        Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
        Order allow,deny
        Allow from all
    </Directory>
    ErrorLog ${APACHE_LOG_DIR}/error.log
    # Possible values include: debug, info, notice, warn, error, crit,
    # alert, emerg.
    LogLevel warn
    CustomLog ${APACHE_LOG_DIR}/access.log combined
    Alias /doc/ "/usr/share/doc/"
    <Directory "/usr/share/doc/">
        Options Indexes MultiViews FollowSymLinks
        AllowOverride None
        Order deny,allow
        Deny from all
        Allow from 127.0.0.0/255.0.0.0 ::1/128
    </Directory>
</VirtualHost>
and also used
sudo chown -R var/www /media/myserver/
and
chmod -R 755 /media/myserver/
still i was not able to connect my /media/myserver and my browser show the following message
Forbidden
You don't have permission to access / on this server.
Please tell anyone how to mount myserver at my var/www, thanks advance
Achu
  • 21,407
8 Answers8
74
You'll have to edit apache2.conf and 000-default.conf to change the document root of apache.
The Apache server is installed on /var/www/html.This is the default root directory of apache.
Either change the root directory of Apache or move the project to /var/www/html.
  1. To change Apache's root directory, run:
     cd /etc/apache2/sites-available
  2. Then open the 000-default.conf file using the command:
     nano 000-default.conf
  3. Edit the DocumentRoot option:
     DocumentRoot /path/to/my/project
  4. Then restart the apache server:
     sudo service apache2 restart
If you get Forbidden You don't have permission to access / on this server after changing the root of apache then do follow these steps
  1. Find the apache2.conf located in /etc/apache2 and open it using:
     nano apache2.conf
  2. Use Ctrl+W and search for Directory (It should be in line 153)
  3. It should look like this
     <Directory />
         AllowOverride All
         Require all denied
     </Directory>
  4. Change it to
     <Directory />
         Options Indexes FollowSymLinks Includes ExecCGI
         AllowOverride All
         Require all granted
     </Directory>
  5. Restart apache
I made a script that changes apache root in a single command. You can find it on my github.
Dan
  • 14,180
Harjot
  • 756
25
Maybe a little bit late. But still..
You should edit your directory permissions in apache.conf under /etc/apache2
Search for this
        AllowOverride None
        Require all granted
</Directory>
and add this code under of it, which gives the permission to access your directory
            AllowOverride None
            Require all granted
    </Directory>
Simply change the document root in your activated configuration. /etc/apache2/sites-enabled/000-default and then Make sure reloading your apache.
So try with this:
<VirtualHost *:80>
    <Directory />
        AllowOverride None
    </Directory>
        AllowOverride None
        Order allow,deny
        allow from all
    </Directory>
        AllowOverride None
        Order allow,deny
        Allow from all
    </Directory>
    # alert, emerg.
    LogLevel warn
</VirtualHost>
Then the proper permission should be given like this:
sudo adduser <username> www-data
sudo chown -R www-data:www-data /media/myserver/
sudo chmod -R g+rw /media/myserver/
Achu
  • 21,407
  1. you modify apache2.conf. Replace /var/www/ with /your/path:
    <Directory /your/path/>
        AllowOverride None
        Require all granted
    </Directory>
  2. Modify the 000-default.conf file:
    DocumentRoot /your/path/
  3. Change the ownership of the directories to yourself from file manager or terminal (e.g. sudo chown pi: path). Without this you will get this error message:
As a quick workaround (safe and quick) you can make the mounting point of your external hard driver to the default root directory ( /var/www by default).
Assigning the mounting point to a per-existing directory is safe but the old content can't be reached unless you unmounted the driver.
To learn more how to create a mounting point refer to this.
I had to make sure the whole path was granted Apache.
chown www-data /media;
chown www-data /media/MNT/;
chown www-data /media/MNT/DISK;
chown www-data /media/MNT/DISK/www-root;
LarsAamo
  • 445
sudo gedit etc/apache2/apache2.conf add this
AllowOverride None
Order allow,deny
allow from all
in virtual configuration :/etc/apache2/sites-available/site.conf
ServerAdmin anilrmg@localhost.com
ServerName anilrmg.localhost.com
ServerAlias www.anilrmg.localhost.com
DocumentRoot /home/anilrmg/projects/code/anilrmg
sudo a2dissite 000-default.conf
Mudit Kapil
  • 2,081
Anil Gupta
  • 111
For those who use VirtualBox guest additions and get you don't have permission to access /on this server despite of everything mentioned above:
If you are trying to set the Apache document root folder to a VirtualBox shared folder,and you have tried everything above and that did not help, there is one more step.
In short, the solution is to add user 'www-data' to the group 'vboxsf':
sudo usermod -a -G vboxsf www-data
You can not change the owner and/or the group of the VirtualBox shared folder, but the solution above worked well for me.
