25
In Ubuntu 13.04 with KDE desktop is there any way to do an action like "Open terminal" in Dolphin? Can it be done using a hotkey?
muru
  • 207,228
Raja G
  • 105,327
  • 107
  • 262
  • 331
In the dolphin file manager just press the F4 function key and that will open a terminal inside dolphin, in the same directory.
Dolphin file manager showing nested terminal window
To open a separate terminal window, press Shift+F4; or right-click in the directory contents pane and choose Actions > Open Terminal Here.
Note: As Dolphin is KDE-based the default terminal emulator it launches is Konsole, so if you only get an empty area instead of a terminal, try running
sudo apt-get install konsole
Zanna
  • 72,312
Raja G
  • 105,327
  • 107
  • 262
  • 331
