12
What Ubuntu software is there to use a webcam as a recording camera (Like a Security System). It NEEDS to detect movement in the room, take pictures and/or record.
Zanna
  • 72,312
Luis Alvarado
  • 216,643
7 Answers7
10
You could try using motion (V4L capture program supporting motion detection), a command line only utility.
To install this from the standard repository, execute:
sudo apt install motion
It's been pretty useful for me. Keep in mind motion will not record any audio.
Notes
  • By default target_dir (defined in /etc/motion/motion.conf) is /var/lib/motion/.
  • On Debian based systems on the config file you might need to change /usr/etc/motion/ to /etc/motion/. Then restart motion service.
  • Remove old files with a cron job. To keep last 60 days would be something like:
    /usr/bin/find /var/lib/motion/ -mtime +60 -and -type f -and -name "*mkv" -delete
Pablo Bianchi
  • 17,371
wxCam supports the movement detection.
Last release: 2011-11.
wxCam is a webcam application for linux. It supports video recording (in an avi uncompressed and Xvid format), snapshot taking, and some special commands for philips webcams, so you can also use the program for astronomy purposes. It supports both video4linux 1 and 2 drivers, so it should work on a very large number of devices.
Pablo Bianchi
  • 17,371
lukasz
  • 2,436
Shinobi (source)
Shinobi is a ZoneMinder alternative.
The Open Source CCTV platform written in Node.JS (Camera Recorder - Security Surveillance Software). From its site:
  • Records IP Cameras and Local Cameras
  • Streams by WebSocket
  • Save to WebM and MP4: Other formats will be added after codec choices are less confusing.
  • API
    • Get videos
    • Get monitors
    • Change monitor modes : Disabled, Watch, Record
    • Embedding streams
Also: Webcamoid is a full featured and multiplatform webcam suite. Check here how to install.
Pablo Bianchi
  • 17,371
guvcview is the best in the smooth video as if you are a recorder.
sudo apt-get install guvcview
Zanna
  • 72,312
Try Cheese, the standard webcam app in Ubuntu.
Its installed by default, go to Applications > Sound & Video
It has recording capabilities (video and sound), and it take snapshots as pictures. But i guess it lacks motion sensor.
MestreLion
  • 20,726
  • ffmpeg
    for video only:
    ffmpeg -f video4linux2 -s 320x240 -i /dev/video0 out.
    for audio and video:
    ffmpeg -f oss -i /dev/dsp -f video4linux2 -s 320x240 -i /dev/video0 out.mpg
  • ZoneMinder surveillance system. Maybe the best and most complex open source tool.
Pablo Bianchi
  • 17,371
jet
  • 7,452
ffmpeg, Cheese, V4L are all great tools - simple to the max - and yet they lack motion detection capability.
If motion detection is a must you should really take a look at ZoneMinder (open source) and/or Xeoma (closed source but has a very simple free mode with motion detector and some notifications).
