I need software which is able to capture images from a webcam and stream them to a web-page.
I already tried a webcam-server, but it uses java applet on the client side for retrieving pictures, which is not supported on my client device (Android tablet).
An alternative may be be something that captures images from a webcam and writes them to the same file, constantly rewriting it. In that case, my java-script on the client side can just use this file to constantly refresh an image.
Any ideas and suggestions are greatly appreciated.
Zanna
  • 72,312
Peter17
  • 253
Yeah you're on the right path. Deal with standard images and update it with javascript.
You should have a look at webcam which is a little command line app that just snaps away and can upload over FTP. If you don't have an FTP server (eg only SSH) you could mount that and have it upload that way.
One note about refreshing the images: stick '?var=' + (new Date).getTime() on the end of the image URL each time you fetch it. This just forces the browser not to use a cached copy. And make sure you don't set the refresh interval too aggressive.
Oli
  • 299,380
To share webcam and mic, you can always just create a jitsi.org meeting (ie, WebRTC; or with any alternative). After letting your browser to access those devices, anyone having the generated meeting link could access.
To remotely assist to other users check this related answer.
To record video check for motion or Shinobi.
Pablo Bianchi
  • 17,371
