I have Chromebook Acer C7 and i like it. It's fast etc. To install *buntu linux on it i did use Crouton. It's a program who install *buntu on ChromeOS without erace the orginal system.
Anyway! I have problem with the keyboard layout. I have Swedish keyboard but the keyboard layout in the system is US keyboard.
I can install Swedish keyboard layout by using this command:
sudo dpkg-reconfigure keyboard-configuration
After that, i have Swedish keyboard layout. But after i reboot i falling back the the US keyboard layout.
(precise)acer@localhost:~$ sudo dpkg-reconfigure keyboard-configuration
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "sv_SV.UTF-8",
LC_ALL = (unset),
LANG = "sv_SV.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_CTYPE to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_MESSAGES to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_ALL to default locale: No such file or directory
LC_ALL = (unset),
Your console font configuration will be updated the next time your system
boots. If you want to update it now, run 'setupcon' from a virtual console.
LC_ALL = (unset),
update-initramfs: deferring update (trigger activated)
Here is /etc/default/keyboard
(precise)acer@localhost:~$ cat /etc/default/keyboard
# Check /usr/share/doc/keyboard-configuration/README.Debian for
# documentation on what to do after having modified this file.
# The following variables describe your keyboard and can have the same
# values as the XkbModel, XkbLayout, XkbVariant and XkbOptions options
# in /etc/X11/xorg.conf.
XKBMODEL=""
XKBLAYOUT="se"
XKBVARIANT=""
XKBOPTIONS="terminate:ctrl_alt_bksp"
# If you don't want to use the XKB layout on the console, you can
# specify an alternative keymap.  Make sure it will be accessible
# before /usr is mounted.
# KMAP=/etc/console-setup/defkeymap.kmap.gz
Here is /etc/default/locale
(precise)acer@localhost:~$ cat /etc/default/locale
#  File generated by update-locale
LANG="sv_SV.UTF-8"
LANGUAGE="sv_SV.UTF-8"
Best Regards Acer
euraad
  • 237
This is an old post but here is the solution I use on 16.04 (Xenial)
Then run:
sudo dpkg-reconfigure console-setup
battlemidget
  • 1,032
  1. Open Terminal
  2. Login with root su
  3. Enter password of root
  4. Update and Upgrade all with sudo apt-get update && sudo apt-get upgrade
  5. Type the following:
    apt-get install console-data
    apt-get install console-setup
    apt-get install console-locales
    apt-get install keyboard-configuration
  6. Reboot and recheck.
  7. Enjoy ;)
akajack
  • 186
