When I try to access my hard disk on Windows I got the following error:
Error mounting /dev/sda2 at /media/debo/2290657790655279: Command-line `mount -t
"ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177"
"/dev/sda2" "/media/debo/2290657790655279"' exited with non-zero exit status 14:
Windows is hibernated, refused to mount.
Failed to mount '/dev/sda2': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
Please can anyone help me on this?
Dan
  • 6,784
The problem is exactly what it says. If your windows has not properly shutdown, Ubuntu would not mount it in read write mode as writing to the disk may corrupt it. You can however mount it in read only mode using the command:
mount -o ro /dev/sda2 /media/debo/2290657790655279
assuming you want to mount it at /media/debo/2290657790655279, otherwise you can use any other empty directory as a mount point. e.g. to mount in "newfolder" in your home directory:
mount -o ro /dev/sda2 ~/newfolder
