Today I bought and mounted my new HDD that I plan to use solely as a storage device. I started with formatting the drive to NTFS filesystem and then proceeded with transferring a couple of GB from an older drive to this new one. Up to this point it all worked without any glitches. But when I disconnected the drive and then connected it again I got this error msg: Error mounting /dev/sdb2 at /media/fz/Red 1TB: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sdb2" "/media/fz/Red 1TB"' exited with non-zero exit status 12: NTFS signature is missing.Failed to mount '/dev/sdb2': Invalid argumentThe device '/dev/sdb2' doesn't seem to have a valid NTFS.Maybe the wrong device is used? Or the whole disk instead of apartition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
My questions:
  1. Why did this happen first of all? I safely removed the disk like I have done a million times, so this can't be the reason. But I did start with a slow formatting and aborted it right away when I realized it would take so long and did a quick formatting instead. Could this be the reason? I also changed the name of the disk and then quickly changed it back.
  2. Error mounting /dev/sda2 at /media According to the above page I should be able to resolve this by typing in mount -o ro /dev/sdb2 /media/fz/Red 1TB in the Terminal (ctrl+alt+T). Is this correct? And what should I expect when I enter that command? Do I have to do enter this command every time I disconnect and mount the disk (I use an external HDD reader so I do disconnect/connect disks all the time)?
  3. If I use this command as recommended, what does it mean for my data? Do I have to format the disk and start all over again again or does it just fix it and I can go on as normal?
  4. If I fix this and get access to my data again, what says that I won't run in to the same problem again? Right now I only transferred a couple of GB to the new disk, but if I transferred the intended 1 TB and run in to the same issue later down the line... the hassle with saving so much data will be too hard. So this goes back to the first question posed I guess. Not knowing what caused this issue in the first place is what worries me, I'm not asking for a seer.
I saw some threads/posts from others with the same issue but it seemed to be connected to Windows installations - I have Ubuntu 14.04 LTS. And they don't go in to detail to answer my questions above.
Clarification: I have two disks: a SSD 120 GB with Ext4 filesystem with Ubuntu 14.04 LTS OS and a HDD 1 TB with NTFS (the disk I have issue with now) that I use solely for storing data.
Reading your issue, it's not clear what you did, and since it's just a "storage drive" why are there 2 partitions on it? If you used the drive as a single storage location, it should be /dev/sdb1 for the partition (or similar depending on devices).
If you have no need for Windows, then yes EXT4 is a more robust file system and should be used with Ubuntu - it's the default file system and should be more stable.
Having said that errors do happen. Is the new drive external? You mentioned you "safely removed"...perhaps something you tried to do something in the midst of the removal process like change names, change mount point, etc.?
Compatico
  • 154
