I have install libreoffice4.1 but when I try to install python-uno It had error
sudo apt-get install python-uno
Reading package lists... Done
Building dependency tree
 python-uno : Depends: libreoffice-core (= 1:4.0.2-0ubuntu1) but it is not going to be installed
I don't know how to fix this. Please help. apt-cache policy python-uno libreoffice-core
python-uno:
  Installed: (none)
  Candidate: 1:4.0.2-0ubuntu1
  Version table:
     1:4.0.2-0ubuntu1 0
        500 http://mirror.cc.columbia.edu/pub/linux/ubuntu/archive/ raring/universe amd64 Packages
libreoffice-core:
  Installed: (none)
  Version table:
     1:4.1.0-0ubuntu1~raring1~ppa1 0
        100 /var/lib/dpkg/status
     1:4.0.2-0ubuntu1 0
        500 http://mirror.cc.columbia.edu/pub/linux/ubuntu/archive/ raring/main amd64 Packages
After add ppa for libreoffice I install but have error like this
The following extra packages will be installed:
  libreoffice-common libreoffice-core
Suggested packages:
  libreoffice-style-crystal libreoffice-style-hicontrast libreoffice-style-human libreoffice-style-oxygen libreoffice-style-tango
The following NEW packages will be installed:
  libreoffice-common libreoffice-core python-uno
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 28.5 MB/56.2 MB of archives.
After this operation, 196 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://ppa.launchpad.net/libreoffice/ppa/ubuntu/ raring/main libreoffice-core amd64 1:4.1.0-0ubuntu1~raring1~ppa1 [28.2 MB]
Get:2 http://ppa.launchpad.net/libreoffice/ppa/ubuntu/ raring/main python-uno amd64 1:4.1.0-0ubuntu1~raring1~ppa1 [284 kB]
Fetched 28.5 MB in 1min 21s (351 kB/s)
(Reading database ... 415424 files and directories currently installed.)
Unpacking libreoffice-common (from .../libreoffice-common_1%3a4.1.0-0ubuntu1~raring1~ppa1_all.deb) ...
dpkg: error processing /var/cache/apt/archives/libreoffice-common_1%3a4.1.0-0ubuntu1~raring1~ppa1_all.deb (--unpack):
 trying to overwrite '/usr/bin/soffice', which is also in package openoffice-debian-menus 4.0-9702
rmdir: failed to remove ‘/var/lib/libreoffice/share/prereg/’: No such file or directory
rmdir: failed to remove ‘/var/lib/libreoffice/share/’: Directory not empty
rmdir: failed to remove ‘/var/lib/libreoffice/program/’: No such file or directory
rmdir: failed to remove ‘/var/lib/libreoffice’: Directory not empty
Selecting previously unselected package libreoffice-core.
Unpacking libreoffice-core (from .../libreoffice-core_1%3a4.1.0-0ubuntu1~raring1~ppa1_amd64.deb) ...
Selecting previously unselected package python-uno.
Unpacking python-uno (from .../python-uno_1%3a4.1.0-0ubuntu1~raring1~ppa1_amd64.deb) ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Processing triggers for shared-mime-info ...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
Processing triggers for man-db ...
Processing triggers for gnome-icon-theme ...
Processing triggers for hicolor-icon-theme ...
if I run
sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of libreoffice-core:
 libreoffice-core depends on libreoffice-common (>> 1:4.1.0); however:
  Package libreoffice-common is not installed.
dpkg: error processing libreoffice-core (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python-uno:
 python-uno depends on libreoffice-core (= 1:4.1.0-0ubuntu1~raring1~ppa1); however:
  Package libreoffice-core is not configured yet.
dpkg: error processing python-uno (--configure):
 libreoffice-core
 python-uno
if I run
sudo apt-get install -f
Correcting dependencies... Done
  libreoffice-common
Suggested packages:
  libreoffice-common
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/27.7 MB of archives.
After this operation, 76.9 MB of additional disk space will be used.
(Reading database ... 415610 files and directories currently installed.)
Braiam
  • 69,112
giaosudau
  • 1,959
python-uno depends of libreoffice-core and libreoffice-core deppends of libreoffice-common, but libreoffice-common is not being installed due openoffice-debian-menus owning the /usr/bin/soffice binary. Is a dependency correlation problem due installing and mixing packages, where python-uno won't install while openoffice-debian-menus is installed. So, method to solve this:
sudo apt-get --fix-broken purge openoffice-debian-menus
sudo apt-get -f install
This will delete the annoying openoffice-debian-menus package, that will allow you to install libreoffice's and sane your system.
Braiam
  • 69,112
If you have installed the packages by manually downloading and installing them, you will get conflicts like this. Why? Because APT can only "see" the packages in repositories. You have decided to install only a certain set of packages earlier on and now that you need another, it will only see the one in the Ubuntu main repositories.
To fix this and to install LibreOffice in a way that you will receive updates, I suggest you to install the LibreOffice 4.1 PPA.
  1. Run
    sudo apt-add-repository ppa:libreoffice/libreoffice-4-1
    to install the 4.1 repository.
  2. Then, run
    sudo apt-get update && sudo apt-get dist-upgrade
    to get fully up to date.
  3. You should now be able to install the latest python-uno compatible with 4.1.
See also Is there a PPA with the latest version of LibreOffice?
gertvdijk
  • 69,427
