74
I use youtube-dl to download files from YouTube. I have tried downloading multiple files, but it is not working out for me. I have to open multiple terminals and start afresh every time I want to download a video.
Can you help me to download multiple files with a single terminal window by just mentioning all the URLs at once? I use Ubuntu 12.04 64-bit.
Zanna
  • 72,312
11 Answers11
75
Shortcuts
If all of the videos are in the same playlist or the same channel, you can save time by using the following shortcuts.
Playlist
youtube-dl -f FORMAT -ciw -o "%(title)s.%(ext)s" -v <url-of-playlist>
...where <url-of-playlist> is replaced by the URL of the playlist and replace FORMAT with any available video format, for example 18. You can use the -F option to see all valid formats like this:
youtube-dl -F 'http://www.youtube.com/some-alphanumeric-string'
Download part of a playlist from start of batch to end of batch
youtube-dl -f FORMAT -ci --playlist-start NUMBER --playlist-end NUMBER <url-of-playlist>
...where <url-of-playlist> is replaced by the URL of the playlist, replace FORMAT with any available video format, for example 18, and NUMBER is the number of the video in the playlist to start/end downloading at.
Channel
youtube-dl -f FORMAT -ciw -o "%(title)s.%(ext)s" -v <url-of-channel>
...where <url-of-channel> is replaced by the URL of the channel and replace FORMAT with any available video format, for example 18.
Videos not in the same playlist or channel
First create a batch file which is a text file containing a list of URLs of videos from YouTube that you want to download. The URLs should be arranged in a list having only one URL and nothing else on each line, with a new line for each URL in the list. Save the batch file with a name that is easy to remember like batch-file.txt. If the multiple files are all on the same playlist, channel or user webpage in YouTube, you can generate a text file with a list that has all the links on that page by running the following command:
sudo apt install jq
youtube-dl -j --flat-playlist "https://<yourYoutubeWebpage>" | jq -r '.id' | sed 's_^_https://youtu.be/_' > batch-file.txt
From the terminal run:
youtube-dl -ct --simulate --batch-file='/path/to/batch-file.txt'
This is the basic command, however you also need to add the formats of the videos that you want to download or else you may find yourself downloading videos with formats that you didn't want. So first simulate your download to see if the format you want is available:
youtube-dl -ct -f 34 --simulate 'http://www.youtube.com/some-alphanumeric-string'
If the video format is not available you will get an error message that says: requested format not available. If the video format is available you will not get any error message when you use the --simulate option. You can also add the -F option to see all valid formats like this:
In the third command I have used the common flv 360p video format:
-f 34. You might prefer to try the flv 480p video format by using -f 35. So after you have added the video format that you want to the command, the command becomes something like this:
youtube-dl -ciw -o "%(title)s.%(ext)s" --batch-file='/path/to/batch-file.txt'
Notes:
I didn't add the --simulate option to the last command, so this command would be executed for real.
karel
  • 122,292
  • 133
  • 301
  • 332
42
You can put the urls one after another, with a space in between. Youtube-dl will download them sequentially. This is a bit simpler than making a batch file.
Notice the --help says youtube-dl --help Usage: youtube-dl [options] url [url...]
Sample input:
youtube-dl http://www.youtube.com/watch?v=fqULJBBEVQE http://www.youtube.com/watch?v=vDbbz-BdyYc http://www.youtube.com/watch?v=OrIFaWJ9Glo
Sample output:
    [youtube] Setting language
    [youtube] fqULJBBEVQE: Downloading video webpage
    [youtube] fqULJBBEVQE: Downloading video info webpage
    [youtube] fqULJBBEVQE: Extracting video information
    [download] Destination: Web Components - A Tectonic Shift for Web Development - Google I_O 2013-fqULJBBEVQE.mp4
    [download] 100% of 238.14MiB in 36:54
    [youtube] vDbbz-BdyYc: Downloading video webpage
    [youtube] vDbbz-BdyYc: Downloading video info webpage
    [youtube] vDbbz-BdyYc: Extracting video information
    [download] Paul Irish on Web Application Development Workflow-vDbbz-BdyYc.mp4 has already been downloaded
    [youtube] OrIFaWJ9Glo: Downloading video webpage
    [youtube] OrIFaWJ9Glo: Downloading video info webpage
    [youtube] OrIFaWJ9Glo: Extracting video information
    [download] Got server HTTP error. Retrying (attempt 1 of 20)...
    [download] Destination: Single Page Web Applications - JavaScript End-to-End (The Hard Stuff)-OrIFaWJ9Glo.mp4
    [download] 100% of 553.10MiB in 42:17
coreyb
  • 530
To download multiple files from YouTube
  1. Go to your desktop and make a text document called list (or any other name). Copy and paste the URLs if files you want to download into the file, one URL per line.
  2. Open terminal and go to desktop
    cd ~/Desktop
  3. To download the files on your list, type (replace list accordingly if you named your file something else)
    youtube-dl -a list
To download a YouTube playlist
Run this command
youtube-dl -citk -format mp4 -yes-playlist VIDEO_PLAYLIST_LINK
  • -c resume partially downloaded files
  • -i ignore any errors.
  • -t use the video title as the file name.
  • -k keep the video on the disk after the post-processing is finished.
  • --format mp4 save the video files as MP4 files.
  • --yes-playlist affirms that the URL that follows points to a video playlist.
pomsky
  • 70,557
youtube-dl -cit --format=mp4 --batch-file=./list-of-youtube-videos-link.txt was what worked for me combining https://askubuntu.com/a/947676/481688 and https://askubuntu.com/a/334097/481688 solutions. I'm recording it here standalone rather than scroll multiple answers again in future.
  • --batch-file=./list-of-youtube-videos-link.txt file with a list of youtube links
  • --format=mp4 mp4 format output desired
MrMesees
  • 251
most straightforward solution would be make a bash script like this
#!/bin/bash
terminal=`tty`
exec < ~/Documents/youtubevideolinks.txt
while read -r line
do
    cd ~/Desktop/TilakDa/
    youtube-dl -f 18 "$line"
done
exec < "$terminal"
just copy and paste the the video links in that txt file in documents folder with each video url in a new line and run this script it will download the videos one by one By default the -f 18option is for 360p video
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Try with bash script:
while read LL ; do youtube-dl "$LL" ; done < your_file
Kulfy
  • 18,154
If you have multiple video URLs just add them in one playlist into your YouTube Playlist by creating a new one or using an existing one.
Then use command below.
youtube-dl -f FORMAT --yes-playlist [url-of-playlist]
The option --yes-playlist will download the playlist, if the URL refers to a video and a playlist.
This is the simplest and quickest option I found for my purpose of downloading hundreds of videos from a website which had videos linked from YouTube.
Paddy Landau
  • 4,658
user669330
  • 31
To download multiple videos you can use this structure. It's similar to @coreyb's response with the addition that you can use it elsewhere in bash, for example with echo. Here are two ways:
Braces
youtube-dl -f FORMAT {url1,url2,url...}
Repeat the last command without the last argument
youtube-dl -f FORMAT url1; !:- url2; !:-url...
Xui
  • 31
Type the command and then type && and type the next command like:
youtube-dl--add-metadata -xic http://(the url) && youtube-dl--add-metadata -xic http://(the url)
Stephen Rauch
  • 1,156
  • 15
Topic is still relevant, so:
  • Get your YouTube link.
  • Remove the first video parameter starting with ?
  • use like this :-)
    youtube-dl.exe --yes-playlist https://www.youtube.com/watch?list=yourlistlink
This works for me.
Zanna
  • 72,312
studen
youtube-dl --retry-sleep fragment:exp=1:20 --write-subs --write-auto-subs --batch-file file_name.txt
Evades by different sleep times
downloads subtitiles, auto generated ones
batch mode of multiple youtube links some playlists some videos
