12
How can I download a YouTube playlist on Ubuntu?
I tried youtube-dl but it's long to change quality, edit crashed file and pause list.
I tried also JDownloader but it takes too much Memory, CPU and it's very slow while downloading.
Is there another method?
anonymous2
  • 4,325
5 Answers5
12
You don't need another program -- you can actually solve your problems, using youtube-dl. Use
youtube-dl -i ..playlist..
The -i flag will cause youtube-dl to continue if it encounters any errors. If one video in the playlist can't be downloaded, it'll skip that video and continue on to the next, thanks to the -i flag.
There is no need to specify any command-line options to specify the quality. The defaults are reasonable: the default is to download the highest-quality video and audio available, which probably makes sense in most cases.
If you don't like specifying flags on the command line, you can put them in youtube-dl's configuration file (e.g., ~/.config/youtube-dl/config).
It's amazing what you can find when you read the manual page!
D.W.
  • 380
You can try Youtube Multi downloader. It's super easy to control quality, but you will need to install downloader support Batch downloads. I use UGet. It's simple and supports queue download.
I use youtube-dl + Youtube-dl GUI, you can Install the two of them as follows :
1. Install youtube-dl :
By default, Youtube-dl is not available in the Ubuntu-16.04 repository. So you will need to download it from their official website. You can download it with the curl command, First, install curl with the following command:
sudo apt-get install curl -y
Next, download the youtube-dl binary:
curl -L https://yt-dl.org/latest/youtube-dl -o /usr/bin/youtube-dl
Next, change the permission of the youtube-dl binary package with the following command:
sudo chmod 755 /usr/bin/youtube-dl
Now youtube-dl is installed.
2. Install Youtube-dl GUI :
By default, this tool is not available in Ubuntu 16.04 repository. So you will need to add PPA for that.
sudo add-apt-repository ppa:nilarimogard/webupd8
Next, update your package repository and install youtube-dlg with the following command:
sudo apt-get update -y
sudo apt-get install youtube-dlg -y
Once Youtube-dl is installed, you can launch it from Unity Dashboard.
Source : Install and Use YouTube-DL on Ubuntu 16.04
Bilal
  • 3,747
There's something similar for standard youtube-dl, but faster:
sudo add-apt-repository ppa:yt-dlp/stable    # Add ppa repo to apt
sudo apt update                              # Update package list
sudo apt install yt-dlp                      # Install yt-dlp
And, as D.W. suggested, but using yt-dlp:
yt-dlp -i https://www.youtube.com/playlist?list=PLbO86FG77std69waOv_othw3NgpCNn_7m
Gryu
  • 8,002
  • 37
  • 53
You can install savefrom adds-ons in your browser, and it will give you the URLs from YouTube playlists.
Cristiana Nicolae
  • 4,570
  • 32
  • 46
