Is there a way to use the cp command to copy a directory and exclude certain files/sub-directories within it?
- 16,703
- 999
- 3
- 9
- 11
Use rsync:
rsync -av --exclude='path1/to/exclude' --exclude='path2/to/exclude' source destination
Note that using source and source/ are different. A trailing slash means to copy the contents of the folder source into destination. Without the trailing slash, it means copy the folder source into destination.
Alternatively, if you have lots of directories (or files) to exclude, you can use --exclude-from=FILE, where FILE is the name of a file containing files or directories to exclude.
-av means archive mode and verbose.
--exclude may also contain wildcards, such as --exclude=*/.svn*.
Copied From: https://stackoverflow.com/a/2194500/749232
If you want to use cp itself:
find . -type f -not -iname '*/not-from-here/*' -exec cp '{}' '/dest/{}' ';'
This assumes the target directory structure is the same as the source's.
Copied From: https://stackoverflow.com/a/4586025/749232
Late into the game but here is a very different solution using plain Bash and cp: you can use a global file specification while having some files ignored.
Assume the directory contains the files:
$ ls *
listed1 listed2 listed3 listed4 unlisted1 unlisted2 unlisted3
Using the GLOBIGNORE variable:
$ export GLOBIGNORE='unlisted*'
$ ls *
Or with more specific exclusions:
$ export GLOBIGNORE='unlisted1:unlisted2'
$ ls *
listed1 listed2 listed3 listed4 unlisted3
Or using negative matches:
$ ls !(unlisted*)
This also supports several unmatched patterns:
$ ls !(unlisted1|unlisted2)
- 16,703
- 5,759
Quick Start
Run:
rsync -av --exclude='path1/in/source' --exclude='path2/in/source' [source]/ [destination]
Notes
-avrwill create a new directory named[destination].sourceandsource/create different results:source/— copy the contents of source into destination.source— copy the folder source into destination.
- To exclude many files:
--exclude-from=FILE—FILEis the name of a file containing other files or directories to exclude.
--excludemay also contain wildcards:- e.g.
--exclude=*/.svn*
- e.g.
Modified from: https://stackoverflow.com/a/2194500/749232
Example
Starting folder structure:
├── destination
└── source
├── fileToCopy.rtf
└── fileToExclude.rtf
Run:
rsync -av --exclude='fileToExclude.rtf' source/ destination
Ending folder structure:
├── destination
│ └── fileToCopy.rtf
└── source
├── fileToCopy.rtf
You can use cp with the ! character.
For example, to exclude the file or files file.txt, test.jpg and the directory nodir, while copying all others from the source directory to the destination directory, you may run:
cp source/!(file.txt|test.jpg|nodir) destination
If you have, for example, a file structure as this one:
├── destination
└── source
├── file.rtf
├── file.txt
├── yes
└── nodir
The result after running the above command is:
└── source (not modified)
└── destination
├── file.rtf
└── yes
Here is an article with information on rsync and cp with exclude: How to cp copy and exclude internal files or directories (equivalent to rsync –exclude)
- 16,703
- 121
Everyone seems to answering with "Use rsync", while I agree that is a very powerful tool its also overkill and presents some risks. The OP asked how to do it with cp and I found this worked combining some of the recommendations others made.
cp -rf !(backup) backup/
This was a simple experiment in copying all the files in a directory to a file called backup in the same directory without cp worrying about skipping a recursive call. Hope this helps.
- 101
- 2
