I wanna copy all file but not including 2 files.
Example:
/var/www/site-domain/htdocs/all files but not including .git and wp-config.php files
sorry for my english :)
Merged w/ my prev. answer: An idea would be, yes it's a long detour, but write a Python script using the OS library & then run that.
Worked on it for a lil while, the code of the Python file is down below - it's also on my GitHub in case you want the .py file itself rather than having to copy-paste it: https://github.com/n3xtd00rpanda/PythonPlayground/blob/master/copyfiles_final.py
Remember to have python3 installed, and use chmod +x to make the file executable.
Did a lot of testing, so hopefully it should work as intended! If it solved your issue, feel free to leave an upvote & choose my answer as one that satisfied your question. :-)
#!/usr/bin/env python3
from fileinput import filename import os, subprocess, shutil, sys from re import search
files = [] full_file_path = ""
def fileCopy(nwd):
for file in os.listdir():
    file_name, file_extension = os.path.splitext(file)
    full_file_path = os.getcwd() + "/" + file_name + file_extension
    new_file_path = nwd + file_name + file_extension
    subs = ".git"
    if file_name.find(".git") == -1 and file_extension != ".git" and os.path.isfile(full_file_path) and file_name != "wp_config" and file_name != "copyfiles_nogitignore":
        print("Copying from: ", full_file_path)
        print("Copying to: ", new_file_path)
        shutil.copyfile(full_file_path, new_file_path)
    elif file_extension == ".git" or file_name.find("git") != -1 or file_name == "wp_config" and os.path.isfile(full_file_path):
        print("Found file: ", file_name, file_extension, " in working directory. Not copied.")
if name == 'main': fileCopy(sys.argv[1])
