So I'm trying to clone the setup of one computer to 4 identical machines on the same network. I don't fancy the idea of meddling with the insides of the computer, so I'm following the method outlined here
However, whenever I try the method outlined in the accepted answer, I get
dd: opening 'dev/sda1':Permission denied
Since the drive I'm cloning is my main partition, I'm running both machines off of live CDs. I thought it might not be working because I can't clone the drive when it's mounted, but running umount /dev/sda1 / says it's not mounted.
I'm not 100% set on using this particular method, if there's some other way that would also get the job done.
StephenTG
  • 257
Try this: press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo -i
That will give you a root shell, that way it'll all run as root.
Mitch
  • 109,787
I've always used Clonezilla when cloning drives for identical computers. It runs off a liveCD and is really easy to use. With this method you can create an img file of the base system. So in a few months if a system crashes you have that fresh image ready to go.
Dan
  • 6,784
